585,702 active members*
4,094 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > How to compile .wxt to .wct
    Jul 2017
    As far as I know, the .wxt file is the source file and .wcp is the compiled that edgecam uses.
    File Extensions Used
    The edgecam version they use is very old (Pre 2000)? They have the newer versions of SolidCAM but the cnc programmers still depend on Edgecam for the rare jobs because it is apparently easier to do it in edgecam and not so much in SolidCAM.
    So I've spent two afternoons tracking down the files needed to be edited. I can't file the file. Under edgecam, when you select the "machine", it shows the filename for the .wcp file but does not show the full path. I have looked under each menu in the menu bar and cannot find any settings for default directories and files.
    How do I compile the .wxt file to a .wcp file? Also how do I know which .wcp file edgecam is using?
    Oct 2003
    127
    Re: How to compile .wxt to .wct
    did you try to search your C drive for " *.wcp " to find any file with that extension?
  1. heidenhain tnc 415 compile plc program
    By gordankkrota in forum Uncategorised MetalWorking Machines
    Last Post: 11-19-2016, 09:18 PM
  2. NL1500 Won't Compile NC Program
    By mcaples in forum Mori Seiki lathes
    Last Post: 08-04-2015, 03:48 PM
  3. C program compile error
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-01-2012, 01:07 AM
  4. Scripter Compile Error. in:M3. M1s
    By Dan911 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2011, 02:39 PM
  5. EMC 2 compile?
    By mkonci1 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:21 AM
