585,712 active members*
4,090 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Gas springs for lid - diy
    Jul 2005
    6
    Guys, need a hand please for choosing gas springs.
    I need to know which lb weight will work for a lift top. Think of a hinged chest top that is parallel to the ground in its closed position, and approximately 70-degrees in its open position.
    Details are:
    20lb top that is 42" deep.
    (If you are standing in front of the handle to open the lid, it is 56" wide and 42" deep)
    What lb rating should my gas springs be?
    Can anyone help?
    John
    Apr 2014
    432
    Re: Gas springs for lid - diy
    There is a diagram calculation out there some where i have used it before if you already have struts to go to method is mount on bracket and temp clamp until you are satisfied with the opening and closing.
  1. Drawbar Springs - Belleville or Die Springs
    By Davidimurray in forum Auto Tool Changer
    Last Post: 05-11-2017, 06:23 AM
  2. Help with chosing springs
    By Danimal25 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-25-2011, 07:28 PM
  3. X2 Gas Springs
    By Tallen in forum Benchtop Machines
    Last Post: 09-23-2009, 10:34 AM
  4. Gas Springs on Knee
    By thosj in forum Bridgeport / Hardinge Mills
    Last Post: 03-23-2009, 02:25 PM
  5. Springs
    By CNCMike in forum Solidworks
    Last Post: 03-20-2007, 05:25 PM
