586,005 active members*
5,130 visitors online*
Results 1 to 6 of 6
    Mar 2017
    7
    Hey all! I need some advice
    Gonna build my first CNC, but i am a newbie to the idea of stepper drivers.
    I need a stepper motor driver for Nema23.
    I found leadshine DM542 on amazon (https://www.amazon.com/Leadshine-DM5...40726&sr=8-25-
    spons&keywords=leadshine+stepper&psc=1), but nothing on them offical website.
    Can i buy this?
    Please, someone help. Thank you in advance!
    Apr 2004
    5737
    Re: Hey all! I need some advice
    I think it's the same drive that Leadshine calls "M542", dropping the initial "D". Sure, you can buy it, but most people here would recommend holding off until you've actually built the machine you're going to put it on. Things can change in the course of a build - or the project never gets built at all - and once you're done with it, you'll have a more realistic idea of what it will take to drive it. You might decide to use servos, or bigger motors than this will drive, or decide to opt for the convenience of a G-540, which has the breakout board built in. And you'll have more time to read up on motors and drives and all the considerations that go into building a motion-control system that works well.
    Andrew Werby
    Website
    Mar 2017
    7
    Quote Originally Posted by awerby View Post
    Hi Awerby,
    Thanks for your help! I found G-540, it very good. But the price maybe a litte expensive. I will think about your suggestion. Find what i need first, before i buying.
    Jul 2016
    18
    The DM542 is an excellent stepper drive updated from Leadshine "M542";
    I've used it myself and am very impressed with its features and performance.
    The DM542 however allows microstepping, use of higher-current steppers, has an integrated heatsink.
    It is a good choice.
    Hi, if you build your CNC as a hobby, I think TB6600H will be OK for your NEMA 23, cheap (6.5$ per piece) but can work well. But if you do CNC as a commercial development, and want to improve your CNC's quality, DM542 may be your good choose,it can let stepper motor work smooth and low noise. it'a about 30$ per piece.
    DM542 is for stepper motor which rated current lower than 4A.
    Mar 2017
    7
    Thanks for your kindly help.
  1. Material advice and advice needed
    By kiyoukan in forum Mechanical Calculations/Engineering Design
    Last Post: 02-15-2012, 08:20 PM
  2. HELP NEED ADVICE.
    By JSRLDesign in forum MetalWork Discussion
    Last Post: 02-18-2011, 05:38 AM
  3. General advice and equipment advice
    By GeorgiaRaised85 in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2010, 11:00 AM
  4. Hi, New & need some advice please
    By ToniBN in forum Community Club House
    Last Post: 02-05-2009, 01:41 AM
  5. New and in need of some advice... well alot of advice!
    By GoonShoes in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2007, 01:03 PM
