586,024 active members*
4,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > X3 X axis lead screw nut dimensions.
    Jul 2006
    887
    Does anyone have or know where I can find the dimensions of the X axis lead screw nut block?
    I am doing a DIY CNC conversion on mine and I forgot to cad the original block before screwing it up
    I would love to find cad files for the mill. I did find a fusion 360 model of the mill, but it was only the big parts with none of the smaller parts IE lead screw supports lead screw nuts .
    Thanks.
    Nov 2005
    222
    Re: X3 X axis lead screw nut dimensions.
    I just happened to measure that last night. 25mm x 60mm x 34.97mm in X, Y, & Z directions.
  1. Bridgeport Z axis screw dimensions/drawing
    By dru86 in forum Bridgeport / Hardinge Mills
    Last Post: 06-26-2017, 05:20 PM
  2. Selection of Lead Screw (Dimensions)
    By Sahl in forum Linear and Rotary Motion
    Last Post: 03-15-2017, 04:42 PM
  3. Lead Screw pitch and Bearings,coupling for lead screw
    By Power_user_EX in forum Linear and Rotary Motion
    Last Post: 06-12-2012, 12:37 PM
  4. X2 X-Axis Lead Screw Key
    By lvittori in forum Benchtop Machines
    Last Post: 12-03-2007, 01:27 AM
