585,978 active members*
4,670 visitors online*
    Sep 2016
    353
    Clamping kit for 6040 CNC
    I want to buy a clamping kit for my 6040 Chinese CNC, but I am totally confused with which size to buy.
    The T slot has following dimensions:
    <work surface>
    | X |
    | Y |
    I hope above looks like a T-slot.
    The stud should go through X and the T nut head should fit Y.
    In my case X is 8.3mm, y is 13.6mm.
    Which kit should I buy?
    Sep 2017
    14
    Re: Clamping kit for 6040 CNC
    What comes with them is just bolts and straps ... eBay sells more if that's what you want ... there is also a small 6 mm metric clamp kit that might work .... standard American bolt size would be 5/16 and regular clamp kit is 3/8 so unless you just want the step blocks and replace the hardware that will not fit ... the real question is what and how do you want to clamp ... I would think most of the time you would want low profile since z movement is limited ... it always sucks to run into a clamp ... I have used all sorts of stuff to fixture and clamp ..even bolts and fender washers ... sometimes a fixture is the hard part on cnc
  1. Clamping
    By Treischl in forum DIY CNC Router Table Machines
    Last Post: 06-11-2011, 12:26 AM
  2. How are you clamping your vise down?
    By mcphill in forum Mikinimech
    Last Post: 01-16-2011, 03:27 AM
  3. Clamping with a rod
    By thatstephen in forum Uncategorised MetalWorking Machines
    Last Post: 05-08-2009, 06:00 AM
  4. magnetic clamping
    By dhiruj in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-28-2007, 08:37 PM
