585,992 active members*
5,097 visitors online*
IndustryArena Forum > CAM Software > Vectric > Curves Instead of Inside Corners???
    Sep 2015
    43
    I have been cutting out some speaker parts lately, and the CAM is driving me crazy. I'm not sure if it's a mach3 problem, or Vcarve, so I may post this in two places...
    I have a series of pockets, and inside profiles, where the software is either eliminating a fillet altogether, only doing a partial fillet where it should be a full dogbone fillet or T fillet, or on inside corners, on one side I'll have a nice sharp corner, but the next one it will just turn into an arc.
    Some of these were cutting just fine, but then I would regenerate a toolpath for some reason, and it would have decided to turn a T-fillet into a plain old corner. If I redraw the exact same geometry, and then regen the toolpath, it will cut fine the next time. Go figure. Some of the features though, like turning a shallow inside corner into an arc, it does no matter what I try. The simulation of the toolpath doesn't show it, but the finished product sure does.
    I'm in CV mode in mach3, with the other settings off. Attached is a screenshot of my settings...
    I just upgraded to this router (4x8 ez router) and it is superior in all ways to my old one, but this bug is really getting to me...
    Any ideas where to start?
    Attached Thumbnails Attached Thumbnails IMG_2123.jpg   IMG_2124.jpg   IMG_2125.jpg   IMG_2126.jpg
    Dec 2014
    103
    Re: Curves Instead of Inside Corners???
    Try Exact Stop In Mach3
    Feb 2009
    192
    It could also be a motor tuning issue probably acceleration and velocity. If Mach3 and VCarve were working on you old router a tuning issue may be the problem with the new router.
  1. Cleaning up inside corners on profile toolpath
    By jmalarke in forum PhotoVCarve and VCarve Pro
    Last Post: 03-14-2015, 04:37 PM
  2. Probing inside corners with the 2010 Screenset
    By Megaplow in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-23-2014, 08:18 PM
  3. Programming Question, Dwelling on Inside Corners
    By nfrees114 in forum Hypertherm Plasma
    Last Post: 01-21-2011, 05:11 PM
  4. Inside Square Corners
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 08-29-2010, 04:07 PM
  5. Milling Tight Inside Corners???
    By Frogblender in forum BobCad-Cam
    Last Post: 05-29-2009, 01:21 AM
