I am working on a 220 with the TM02 control. The spindle will sit still when the machine is first turned on but after the first time it is started (MDI or under program control) It will not stop spinning until the power is shut off. It also will not go lower than 560 rpm and does not stop with reset or e-stop. It will go up to ~ 3000 rpm if I remember right and you can speed up / slow down the spindle with the speed control or by MDI.
I looked and couldn't find a zero or balance on the drive or any way to adjust this.
Help please
TIA,
Eric
