585,978 active members*
4,517 visitors online*
Results 1 to 9 of 9
    Mar 2015
    53
    Glass etching/engraving?
    Are laser engravers suitable for engraving glass? (flat and cylindrical)
    Is a CNC router type machine a better choice?
    Anyone here doing glass?
    Jan 2008
    940
    Re: Glass etching/engraving?
    It depends on a lot of little things. Are you talking one offs or lots of the same. For one offs cutting a mask and using etching cream is better.Gives a nicer finish.
    Jul 2005
    2415
    Ethic glass (Aka Sand carving) is best gone with a Vinyl cutter to make a mask in a cheap paint vinyl, unless you want deep carving . Then you sand blast it with aluminium oxide or carbide grit. It takes an inexpensive vinyl cutter , cutting software and a snad blast cabinet. Biggest time consumer is masking off the rest of the object from over-spray. You can make one or one hundred of a design. There are entire groups dedicated to glass etching but it called sand carving . If you wan to make one of something just do the etching acid . If you want to do multiples or make several of different designs then the sand carving is the way to go. There are all kinds of glass things that are fun to carve. Beer mugs, wine glasses, clear coffee cups, etc.
    Mar 2015
    53
    Quote Originally Posted by fixtureman1 View Post
    I have tried the stencil/paste method but I was looking for something a little more 'mass production' , say 50 off quantities of the same graphic.
    Sep 2005
    1740
    A good co2 laser will etch glass or frost it just fine. Just do not cheap out and for round objects a rotary is needed. A lot cleaner and faster than sandblasting. It takes some time to get the right settings for what your going to do.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Mar 2012
    378
    I have done a lot of glass on a 40W CO2 K40 laser with a Lightobject DSP conversion. It does a great job. A bigger laser will do it faster, but I can do a design on a 4" square tile in probably 5-8 minutes. I have also done granite plaques. I just cut up granite tiles from Home Depot.
    Jul 2017
    10
    I do lots of glass and mirror. I will sometimes laser it but not crazy about the texture. What I do mostly is cover the glass or mirror with vinyl then laser it. That will etch the glass and also create a stencil on it with the vinyl so I can give it a quick spray with the sandblaster to get the texture I want.
    Dec 2019
    How to professionally Mat the glass at home. See here https://www.youtube.com/watch?v=cAgchY0ZtgY
    FROSTING OF GLASS. PROFESSIONAL CREAM. You can buy in Sacramento. https://www.youtube.com/watch?v=bS85BvojYqg
    Nov 2019
    11
    Yes, Co2 laser engravers are certainly worked for glass engraving, for cylindrical things you need a rotary.-frank from aeon laser www.aeonlaser.net ([email protected])
  1. etching glass or mirrors
    By turkgeltz in forum Glass, Plastic and Stone
    Last Post: 12-18-2019, 06:05 AM
  2. having a little trouble etching glass, can anyone offer suggestions???
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-16-2013, 07:43 AM
  3. Help with an interesting project (flat glass etching)
    By cncgordon in forum Employment Opportunity
    Last Post: 03-24-2010, 12:15 AM
  4. Seeking alternative ideas to glass etching
    By machinecrafter in forum Community Club House
    Last Post: 11-17-2009, 05:44 PM
  5. Replies: 0
    Last Post: 08-30-2009, 12:49 AM
