Not having worked with a CNC router before, i'm curious to the actual operation when it comes to the base board or table. Is it sacrificial? does it get all cut up when cutting through the work piece?
I would imagine to get a get edge cut you would want to go a fraction deeper than the work piece, but then your cutting into your base. This seems fine if using a sacrificial board but what about if you have a vacuum table?? You wouldn't want to be cutting into to vacuum table and replacing that. Especially some of the aluminium ones i've seem here...
If anyone can shed any light on this it would be greatly appreciated.
Matt
