585,700 active members*
4,258 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 412 Upper Z Limit Switch
Results 1 to 7 of 7
    I have an Interact 412 that is acting like the upper Z limit switch is stuck closed. I am not certain where the limit switch is located in order to check it out.
    Any help in pointing me to it would be appreciated.
    Kevin
    Sep 2005
    250
    Re: Bridgeport Interact 412 Upper Z Limit Switch
    It's right below the light on the right side of the head.
    Thanks for the help. I removed the front cover to get a better look at that area behind the light. Is the switch the item pointed out by the yellow arrow, or is it located closer to the red arrow.
    This is a new install and it needs cleaned real bad, I am also open to suggestions on what will clean this thick oil off.
    Sep 2005
    250
    Look under the light the switch is mounted on the head.Attachment 368862
    Put 2 fingers behind the limit switch and you will feel the 2 posts , push them in and let them come back out.
    You may have to lube them up a bit.
    Sep 2005
    250
    I have found if the machine sits for a while like when i go on vacation they sometimes stick.
    Thanks for the help! It was hiding in plain sight I will clean it up and see if that helps.
    The switch contacts were sticky and after cleaning them up, all three plungers are operating smoothly but unfortunately I am still having the same issue. I wanted to include a screen shot here.
    The Z axis thinks it is at 16" but in reality it is physically closer to 5". Does this help shed any light on why I continue to get a Z axis over travel alarm? Do I possibly have some setting out of whack?
  1. Bridgeport Series II Interact 2 EMC retrofit -- limit switches
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2010, 01:15 AM
  2. Help with Bridgeport Interact Series 1 MK2 Stuck on the Limit Switches
    By mwibbels in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2009, 09:33 PM
  3. Bridgeport Series 1 Limit Switch
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2005, 04:28 AM
