Re: G214
Hey guys,
We are releasing a new revision of the G214 that fixes the self test problem you are describing. The self test was for a fixed number of pulses, which would mean your motor rotation would change dependent on the resolution you have it set to.
The new revision uses a much easier self test, which can be used even when connected to a machine with a paused program, will move the motor one revolution CW and one revolution CCW and return to the same microstep location that it started on. This will be resolution independent and does not require the button to be held down.
We have quite a few improvements to the G214 that we made with this update, and if you like you can send your drives in for reflashing of the firmware and hardware upgrade. The main improvements are to anti-resonance compensation and short circuit protection, and can be backwards compatible with older PCBs.
Marcus Freimanis
www.geckodrive.com
