Hello
Any ID help on this microproto 2000
thanks
Rick
Hello
thanks
Rick
The single parallel port indicates this has the step and direction board fitted and the extra DIN socket on the top corner has a few extra connections to the parallel port. Pinout SDBoard 25pinDPinout - Model Engineers Digital Workshop
It will work with Mach3 with the Mach3T2k or Mach3T2kmm config files from Mach-in-a-box Gallery - Model Engineers Digital Workshop
Lester Caine - G8HFL
http://medw.co.uk - Home of electronics for the Model Engineer
Do you have the mill that goes with it, or just the control box? Are you having a problem with it?
I do have the Mill as well and it is in shop getting cleaned and repaired and updated.
I just need mach3 and a PC to run it.
I order a few parts to update and repair a few systems. 1. new bearings for the z lead screw and 2. a updated z nut for z axis .
I am not sure what i am doing with the CNC part!!!!
So and comments will be welcome
Rick in Longmont
