585,894 active members*
4,414 visitors online*
IndustryArena Forum > CAD Software > Autodesk > How to reduce segments in DXF file
    Mar 2013
    6
    Hello! I am extracting points coordinates (X,Y) from DXF file. The problems is that there are tens of thousands of points extracted, but I need up to few hundred points. How can I reduce the number of points and segments. The files are exported from Eagle (PCB design) and it is not too complex. I can't export new files with smaller amount of points and lines, but I can work with the DXF files using AutoCAD. Thanks a lot!
    Feb 2018
    59
    Re: How to reduce segments in DXF file
    i worked with a customer that did that type of work ,,,,this software Altium Designer ,,,,is useful
    https://keysoftwareservice.com/
  1. G03/2 vs arc segments!
    By Machineit in forum BobCad-Cam
    Last Post: 09-12-2019, 09:24 PM
  2. ELLIPSE ARC SEGMENTS
    By RAF. in forum BobCad-Cam
    Last Post: 01-13-2014, 06:38 AM
  3. Arcs and segments
    By Spencer myers in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-02-2013, 12:41 AM
  4. Cut Copper bar into segments
    By Johnnybgood3 in forum RFQ (Request for Quote)
    Last Post: 07-01-2011, 12:53 AM
  5. RFQ: Circle segments
    By slick_rick in forum Employment Opportunity
    Last Post: 07-06-2007, 07:03 PM
