585,949 active members*
3,923 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > VCarve Pro V9 upgrade No longer able to import 3ds files.
    Nov 2016
    12
    I upgraded VCarve to V9 and now I can't import 3ds files that I was using with V8.5. I was wondering if anyone else was having the same problem and if they found a solution? If I convert them to STL files they work fine. I attached the file that I am having trouble with.
    Re: VCarve Pro V9 upgrade No longer able to import 3ds files.
    Your issue has been posted to Vectric's beta forum. If Vectric can reproduce the issue, I'm sure that they'll fix it.
    It crashes for me to in the latest Aspire.
    Nov 2016
    12
    Are you running windows 10?
    yes
    Nov 2016
    12
    It seems like the problem might be with the combination windows 10 and V9. People running windows 7 seem to get it to work.
  1. Import .dxf files into NC500
    By niki2014 in forum CNC Machining Centers
    Last Post: 12-01-2019, 10:24 PM
  2. Help with vcarve pro upgrade
    By JenK in forum Community Club House
    Last Post: 12-12-2013, 11:08 PM
  3. Where are the .pp files for VCarve Pro?
    By vger in forum Post Processors
    Last Post: 11-01-2013, 06:17 AM
  4. how to import .igs files to cut in Aspire?
    By Treojohn in forum Aspire
    Last Post: 06-07-2013, 08:58 AM
  5. import from vcarve pro to bobcad 23/24
    By greggm in forum BobCad-Cam
    Last Post: 01-06-2011, 03:20 PM
