585,556 active members*
3,456 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > Dose anyone make Precision Height Gage Pins
    Mar 2014
    26
    Is there anyone who makes precision pin gages to check length instead of the diameter? I am needing one that need to be 1.000 long and needs to be certified. For my application the body needs to be around .500 but again the diameter will not be gaging anything. We are not able to use gage blocks for this application, that is why we are looking for a round pin type.. Thanks in advance for any information !!
    Aug 2007
    27
    Re: Dose anyone make Precision Height Gage Pins
    you can try using a calibration standard used for calibrating 1-2” micrometers but I’m not sure if the are certified.
    Mar 2014
    26
    Yes we thought of that but the Diameter is .250 and we need a diameterof .500 for our application
  1. Mahr Digimar CX1 Height Gage Retrofit
    By gernoff in forum Calibration / Measurement
    Last Post: 10-09-2014, 02:43 AM
  2. Weird Question 'bout Gage Pins and Thru Holes
    By eliot15 in forum MetalWork Discussion
    Last Post: 10-19-2011, 12:00 AM
  3. Tool Height Gage For Mills
    By SKEETO in forum CNC Machine Related Electronics
    Last Post: 12-18-2007, 09:58 PM
  4. how's dose a bridgeport make it self
    By mog5858 in forum Bridgeport / Hardinge Mills
    Last Post: 11-20-2006, 05:23 AM
  5. Height offset gage
    By moniker in forum Calibration / Measurement
    Last Post: 08-18-2006, 06:30 AM
