586,000 active members*
4,764 visitors online*
    Oct 2013
    84
    Unhappy GCODE Problem
    Hi Guys, I'm a newbie and recently acquire a Fadal. I'm trying to figure out the output of my post and I couldn't seem to get it right, I'm hitting the Z limit everytime I start the program. Can someone please help. thanks in advance! code output below.
    N2 G00 G17 G20 G40 G80 G90 G94
    N4 T18 M6 G43 H18
    N6 ("D-DRILL")
    N8 S2800 M03
    N10 G00 G90 G54 X2. Y-0.5 A0.
    N12 M08
    N14 Z0.5
    N16 G98 G81 X2. Y-0.5 Z-0.875 R0.125 F17.
    N18 G80
    N20 M09
    N22 M05
    N24 G0 G91 G28 Z0
    N26 G0 G90 X0 Y5
    N28 M30
    Aug 2013
    18
    Re: GCODE Problem
    Move the g43 h18 to line 14 and try again
    Sent from my SM-G900R4 using Tapatalk
    Dec 2008
    3109
    Re: GCODE Problem
    I agree with kla64
    Code:
    N4 T18 M6
    N6 ("D-DRILL")
    N8 S2800 M03
    N12 M08
    N14 G43 H18 Z0.5
    N18 G80
    N20 M09
    N22 M05
    N24 G0 G91 G28 Z0
    N26 G0 G90 X0 Y5
    N28 M30
    But ensure you have the correct signed direction of the value in :-
    - G54 Z field ( normally-ive ) ( distance from reference point on spindle to the part origin )
    - length offset #18 field ( normally +ive ) ( distance from reference point on spindle to the tool tip )
    Oct 2013
    84
    Re: GCODE Problem
    Thanks!
    Oct 2013
    84
    Re: GCODE Problem
    Thanks Guys! I've updated my post and only gave me an option (True/False) to specify the "Tool start level" which is 1"(above the part) after G43 H1 which then follows up with Z0.5 after M08, i assume this is fine. I've included my new code output below with additional tool change.. the reason for that.. tool/fixture offset seems screwed up after watching multiple YouTube videos and I'm really hoping that the code is causing it. Can someone look into my code if there's something odd/recommended changes? I can only test the code on the machine when i get home.. would be great if i can get the code output validated before i experience another close call crash.
    N4 T18 M6
    N6 S2800 M03
    N8 G00 G90 G54 X2. Y-0.5 A0.
    N10 G43 H18 Z1.
    N12 M08
    N14 Z0.5
    N18 G80
    N20 M09
    N22 M05
    N24 T19 M6
    N26 S400 M03
    N28 G00 G90 G54 X2. Y-0.5 A0.
    N30 G43 H19 Z1.
    N32 M08
    N34 Z0.5
    N36 G98 G84.1 X2. Y-0.5 Z-0.56 R0.125 F15.748
    N38 G80
    N40 M09
    N42 M05
    N44 G0 G91 G28 Z0
    N46 G0 G90 X0 Y5
    N48 M30
  1. Gcode or problem with my CNC 3040T?
    By PhilipY in forum Chinese Machines
    Last Post: 02-22-2016, 09:42 PM
  2. gcode problem
    By IonutPatrut in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-18-2012, 09:48 AM
  3. Cam to gcode problem
    By Sonicmook56 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-24-2007, 02:01 PM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. dxf to gcode problem...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-19-2004, 07:02 AM
