585,994 active members*
4,600 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > How many passes for accurate cut?
    May 2017
    20
    Hello,
    I think I'm missing something. I've been cutting MDF and abs with success but I have difficulty getting accurate cuts in only one pass. If I run my code three times I get somewhere close to the correct distance.
    For example, a 9mm hole will come out at 8.6mm at the first pass and end up at 8.95mm after the third or fourth pass. I need to mention that what I call a pass actually is three times going around the hole circumference.
    Could that be an end mill issue, I'm using some Chinese end mill? Machine is functioning properly and calibrated properly.
    Sent from my Nexus 5X using Tapatalk
    Re: How many passes for accurate cut?
    Sounds like a machine rigidity issue.What kind of machine is this?
    May 2017
    20
    Chinese CNC 3040 with 800W spindle.
    Apr 2015
    113
    yep thats it. Add finish passes in your CAM. The larger end mill will also help, hopefully. Reduce your bore stepdown as well
    Luthier/Woodworker/Machinist in NS, Canada.
  1. Finishing Passes
    By laserpilot in forum Vectric
    Last Post: 07-29-2012, 02:13 AM
  2. G76 Number of Passes
    By eliot15 in forum G-Code Programing
    Last Post: 04-09-2011, 12:51 AM
  3. finishing passes of G76
    By sinha_nsit in forum Fanuc
    Last Post: 12-23-2010, 08:23 PM
  4. Roughing Passes Exceeding Finishing Passes
    By phoodieman in forum Mastercam
    Last Post: 03-01-2009, 01:21 PM
  5. Can't get multiple passes in v3.0
    By Vogavt in forum Uncategorised CAM Discussion
    Last Post: 01-26-2008, 10:57 PM
