using the TB6560 manual I have added more detail to this diagram
Attachment 369478
"1-The Probe i Put One or two wires? where? on the tb6550 or on the Arduino D06?"
you need a two wire connection - ground and D06 on the arduino ,
using the TB6560 boards input circuit will give the ATMEL IC on the arduino some protection
I dont know what is that you mean(sorry)
on the diagram I have shown the probe being connected to the pin 13 input on the TB6560 board
Two wires. So link a wire from pin 13 to D06. And the ground wire, where a link?
one advantage with the Arduino uno you have is a replacement ATmega328 pre programmed with the Arduino UNO 16 MHz Bootloader is available
I dont know what is for (sorry) Is good?
A000048 ARDUINO, Microcontroller, Pre-loaded with Arduino UNO 16 MHz Bootloader, ATmega328, DIP-28 | Farnell element14
"2-Looking the manual in the link above Mach3 show only one output 1-pin 9? Does not show output"
not sure what the equivelent is on the Estlcam or what you want to control
I mean that the Mach3 Window show output 1 to pin 9. Not to pin 17.
3-Looking the manual...show x, y, z enable pins 2, 6, 14. Where i link them on Arduino?
the simple solution could be to connect the TB6560 boards enabe inputs to +5V from the arduino
You mean to link the 2,6,14 to 5V (on the left Arduino board-behind 3,3V-Power?)
"4-i don't know what is to link on D04, D05, D07 on Arduino"
I would use the D04 to control the relay on the TB6560 board to switch the spindle motor on and off , or Vacuum pump for dust collection
My spindle Strat and stop externaly. There isnt board connection.
D05 is a PWM signal could be used to control a motor speed control board
I dont know what pin to link here . PWM?
D07 not using Estlcam I'm not sure what kind of error D07 monitors could it be an E-stop ????
I dont know too
Mach3 window(manual link) show e-stop to pin 13...
"5-the cnc does not have limit switchs, so what link on D08-D13 on Arduino."
if Estlcam is like Mach3/4 leave them open circuit and set up Estlcam for no limit switches
( an alternative way , if the default Estlcam setup is for a normally closed switch to ground you could hard wire the D08-D13 inputs to the arduino ground )
And pins 10,11, 12. (D08-D10)
"6-When show pin 7, for exemple, on the manual, a considera the db25 female or male? I'm confused..."
the TB6560 board has a 25 pin D-type plug (male) for the connection to a PC's parallel printer port
so the wires from the arduino need to be connected to a 25 way D-type socket (female) to replicate the socket on the back of a PC
for example the arduino A0 ( X Dir output ) needs to be connected to pin 2 on the TB6560 boards 25 pin plug
I bought an adapter. See the photo
Is a female db25. I need to know what pin 2, for example is. Is a see the female (front), pin 2 is the second hole right to left, so the the male pin Will be pin 12, ir a see the male db25(front). Understand what i Mean?
Thank you very much for the attention John! You are helping me so much!!
Cheers!!! 👍👍🙌🏻
John
