585,996 active members*
4,544 visitors online*
Results 1 to 7 of 7
    May 2009
    107
    Replacing bridgeport DX 32 drive capacitors
    Working on bringing a Torq Cut 22 back to full operation by troubleshooting and repairing the A axis drive card. The card was originally driving the X axis when it had problems and the A drive card was moved to X. That solved the X's problems and confirmed the card was bad.
    I just bought the machine, which is in otherwise good operating condition (paint sucks)and while I'm setting it up I thought I would take a look at the board. One of the two capacitors on the board has broken loose from the traces and is definitely a problem. The traces look to be in acceptable shape and before I just check it with a meter and then reinstall, I thought it would probably be best just to replace all the caps on all the drive boards.. 1996 was a long time ago ( for a machine, not me )
    Here is a picture I took of the cap. My google fu has failed me and I can't find a same size cap in my searching...
    Can anyone suggest a replacement and source? I have attached a picture of the caps to this post...
    Dec 2005
    504
    Re: Replacing bridgeport DX 32 drive capacitors
    Quote Originally Posted by Steve_Watkins View Post
    It's a Sprague 673D series. According to the Vishay/Sprague replacement table: https://www.vishay.com/docs/28398/al...placements.pdf The no longer offer a substitution.
    MATURED SERIES DESIGN REMARK REPLACEMENT SERIES
    673D / U673D Radial General purpose, 105 °C No replacement
    Based on the replacement table it appears to be a general purpose aluminum electrolytic capacitor. I would plug in the important values into Digikey's capacitor search and find something comparable. It is 180uF, 105 degrees, 250V. You should also measure the diameter, height, and lead spacing, so you can find one with similar physical characteristic. Being general purpose I suspect +/- 20% on the tolerance.
    Digikey had about 50 that meet the basic specs but I do not know the physical size the the sprague.
    The UCC were Sprague's low esr series... I think.
    May 2009
    107
    Thanks for the help... Should be able to find something now!
    May 2009
    107
    I went ahead and removed the loose cap and tested it... Rated at 180, tested 197...
    I'm going to have to repair the pads and one trace but it's not too bad...
    I did find one area of the board where a component had been removed and the solder left sloppily on the board. I pulled the x and y boards that are working and found that the component looks to have never been installed on those boards, holes looked factory soldered. Glad I don't have to track down something else!
    May 2009
    107
    I repaired the pad and reinstalled the old cap. Put the card back in and so far it seems to be working fine... I did find a part number for a cap that is rated the same and almost the same physical size, just a little smaller. For now I'm just going to leave it alone until it acts up again...
    Dec 2005
    504
    Congratulations!
    May 2009
    107
    For anyone looking for these caps here are the ones I'm ordering from mouser... EKXJ251ELL181MM25S United Chemi-Con | Mouser
  1. Meldas Replacing Spindle Drive
    By Jack2012 in forum Mitsubishi controls
    Last Post: 07-25-2012, 06:46 PM
  2. Replacing Fanuc AC Spindle Drive
    By barchdesigns in forum Fanuc
    Last Post: 04-22-2012, 06:35 PM
  3. Replies: 6
    Last Post: 01-24-2012, 09:28 PM
  4. Replacing Bridgeport series 1 spindle bearings
    By A.A in forum Bridgeport / Hardinge Mills
    Last Post: 02-28-2009, 08:03 PM
  5. Replacing Floppy Drive on Machine Controls
    By ObrienDave in forum DNC Problems and Solutions
    Last Post: 08-01-2005, 02:29 AM
