585,759 active members*
3,889 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Leadwell LTC-20P w/ Fanuc control OTF
Results 1 to 7 of 7
    Jun 2016
    20
    we have the follwing alarm,
    alarm # 1013 TR.. NOT BRAKE.
    We can't find it in any of our manuals. Could someone advise us on this. Thanks.
    Aug 2007
    793
    Re: Leadwell LTC-20P w/ Fanuc control OTF
    this alarm machine specific. you should look into ladder and look for answer there.
    Jun 2016
    20
    I thank you for your reply. Now i just found out that you just can't go to the para/dnos page and page to the ladder diagram. I was told that i had to set a parameter to activate taccess to the ladder. is this really valid info. They said they couldn't remember which parameter. Could you help with this?. Thanks.
    Aug 2007
    793
    parameter 60#2 dynamic ladder display
    if you have paper copy of ladder you may check line where G119.0 is to be activated
    Jun 2016
    20
    Thanks, we have a small manual marked PMC. Whether it is for this machine i will have to check. this machine was bought, supposedly in working condion. But, i haven´t been able to do much with it yet. i guess my priority will be to try and get the turret to jog without getting alarms,
    1013 TR. BRAKE, which i know is turret brake, thanks to your help.
    1014 PLS. TURRET CW, comes up when i jog turret and it stops at pos. "supposedly".
    1011 TURRET NOT RDY.
    I am trying to clear the turret problem first before going on to other faults.
    I really appreciate your help. regards.
    Hello,
    We lost all parameters for the same
    LTC-20P Fanuc 0TF
    Please help, share or sell NC parameters
    and diagnostics (PMC parameters), your
    call
    My email address
    [email protected]
    Thank you
    Jolulank
    Quote Originally Posted by barnesven View Post
    www.doctornumerico.com
    cnc physicians
    Jan 2019
    My machine leadwell LTC 20P O-T series lose the parameter
    After key in the parameter, my spindle speed can't reading display show the reading is 1 or 2 only whatever i comman m3 s50 or s500 or s1000 also reading 1 or 2 but spindle chuck is got turn
  1. Leadwell MCV 550 with a Fanuc 10MA control small c error on master PCB
    By trx-350 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-31-2015, 07:18 AM
  2. LEADWELL MCV-OP WITH MITSI MELDAS M3 CONTROL
    By trebortrebor in forum Mitsubishi controls
    Last Post: 02-05-2014, 10:50 PM
  3. Leadwell w/Mitsubishi control won't change tools - help!
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2013, 05:06 AM
  4. Leadwell 550D With Fanuc OM control
    By KLPerformance in forum Fanuc
    Last Post: 03-02-2011, 02:52 PM
