585,997 active members*
4,727 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > New to the Okuma lathe with a U10l control
Page 2 of 3 123
Results 21 to 40 of 43
  1. #21
    Aug 2017
    16
    Re: New to the Okuma lathe with a U10l control
    this is all that you use to cut the threads it seems way simple compared to what fusion spit out Im assuming that the G0 x1.273z-3.112m8 is this basically you "zero" for this part and could you also break down the G71 line for me as to what those values are for I'm new too the lathe
  2. #22
    Jun 2015
    4154
    Quote Originally Posted by newton11n View Post
    Ok I tried this although it did not produce an error it did not cut threads either it basically acted like a turning program
    this may be because it cutted only the 1st pass on the thread, thus a single G32 will only go once towards Z-
    to cut the thread, you need all G32s, and in each one you may need both x&z
    so :
    Code:
    (01156.MIN)
    N10 G50 S2000
    N11 G0 X400.
    N12 G0 Z400.
    (THREAD1)
    N13 T020202
    N14 M8
    N15 G94
    N16 G97 S500 M3 M41
    N17 G0 X2.8 Z0.1969
    N18 G0 Z0.3181
    N19 G1 X1.9496 F39.3701
    N20 G32 X1.9496 Z-1.2431 F0.0787
    N21 X2.065 Z-1.3009 F0.0787
    N22 G0 X2.8
    N23 Z0.3181
    N24 G1 X1.9311 F39.3701
    N25 G32 X1.9311 Z-1.2339 F0.0787
    N26 X2.065 Z-1.3009 F0.0787
    N27 G0 X2.8
    N28 Z0.3181
    N29 G1 X1.9168 F39.3701
    N30 G32 X1.9168 Z-1.2268 F0.0787
    N31 X2.065 Z-1.3009 F0.0787
    N32 G0 X2.8
    N33 Z0.3181
    N34 G1 X1.9049 F39.3701
    N35 G32 X1.9049 Z-1.2208 F0.0787
    N36 X2.065 Z-1.3009 F0.0787
    N37 G0 X2.8
    N38 Z0.3181
    N39 G1 X1.8943 F39.3701
    N40 G32 X1.8943 Z-1.2155 F0.0787
    N41 X2.065 Z-1.3009 F0.0787
    N42 G0 X2.8
    N43 Z0.3181
    N44 G1 X1.8943 F39.3701
    N45 G32 X1.8943 Z-1.2155 F0.0787
    N46 X2.065 Z-1.3009 F0.0787
    N47 G0 X2.8
    N48 Z0.1969
    N49 M9
    N50 G90 G0 X400. Z400.
    N51 M2
    also, like mr wizard said, try G33 instead of G32, and all stuff from post #14
  3. #23
    Apr 2016
    74
    yes the x is the dia it is starting at z is where the threads start, b angle of thread, d depth of cut, h first depth of first pass h height of thread, f feed rate.
  4. #24
    Apr 2016
    74
    N13 T020202
    N14 M8
    N15 G94
    N16 G97 S500 M3 M41
    N17 G0 X2.8 Z0.1969
    N18 G0 Z0.3181
    N22 G0 X2.8
    N23 Z0.3181
    N27 G0 X2.8
    N28 Z0.3181
    N32 G0 X2.8
    N33 Z0.3181
    N37 G0 X2.8
    I have never seen a threading program
    that long. canned cycles are not normally that
    long. I am not sure what that is??
  5. #25
    Aug 2017
    16
    ok looking at your sample program I see your feed is 1/18 is this your thread pitch? if so am I correct in assuming that for a 12 tpi I would use 1/12
  6. #26
    Jun 2015
    4154
    hey newton, that cam spit out a code for threading with an infeed patern at 38 degrees
    this is the way to attack threads with full control
    however, i can not say if this works as it should, because also start Z may need shifting, so to achieve a proper infeed pattern
    well, even so, each pass is shorter among Z, and this may lead to increased insert life spam
    but i guess you were looking for a simple way to do it, and G71 may be just ok for you
    in all cases, G32/G33 will deliver anytime where G71 will fail ... what can i say ? i hope all your threads to work with G71
  7. #27
    Jun 2015
    4154
    actually that is your sample
    take it easy, one step at a time ... all the best !
  8. #28
    Apr 2016
    74
    Cool Re: New to the Okuma lathe with a U10l control
    yes, you are correct.
    as for this,
    hey deadly kitten-
    (in all cases, G32/G33 will deliver anytime where G71 will fail ... what can i say ? i hope all your threads to work with G71 )
    please share with us how it fails, i guess 25 years has not taught me as much. how would a good machine fail at making threads? they are not really hard to make for most of us,
    but it must be a up-hill battle for you. you make things way to hard my man. Kindly!
  9. #29
    Jun 2015
    4154
    Quote Originally Posted by skywalker4 View Post
    one day i will go into more details about threading codes ...
    here are some cases that i could not handle with G71
    ... deliver a stable setup for thousands of parts with 0.03 tolerance, reducing the frequency of edge failure
    ... use some inserts that were pretty pretentious and replacing them would have created ( days ) downtime
    ... keep the dimensions somewhere near the NO-GO caliber for tight tolerance, thus increasing the life spam of the insert
    ... eliminate passes from a G71 cycle, thus using my own approach, which leads to time gain
    .. chamfering and threading with the thread insert ( some kind of a mix code )
    those were cases where an intervention was required, but there is also prediction : at this point i take into consideration insert geometry, and based on its profile deviation compared to the iso profile, i can generate code specific to each thread tolerance class
    and fun parts begins when same producer can not deliver same geometrical tolerances for its inserts ... something like last lot worked, newer ones are trash
    i was given drawings with extra specification on thread dimensions, and many calibers : go no-go thread, go-no go cilinder, go no-go for the go, go no-go for the no-go, etc
    i could have not delivered those parts without knowledge into threading assemblies tolerances ... and i asked for help at a near by tool factory
    ps : by the way, if you are interested into desynchronization palier, you may check post4 in here : http://www.cnczone.com/forums/okuma/327510-optimal-clearance.html
  10. #30
    Jul 2010
    287
    Kitten, I do agree that you're making the G71 way too difficult.
    Also, to insinuate that the rest of us do not cut tight tolerance threads in any production environment is pretty insulting to others.
    I'm not saying your way doesn't work, but I can guarantee that G71 is more than capable of any threading needed.
    Using G71 makes threading programming substantially easier and offers you the ability to do multiple types of infeed cycles my merely changing a couple M codes on the end of the line.
    There's no reason whatsoever that a G71 isn't capable of stable manufacturing.
    For those not in the know, G71 is a canned cycle that Okuma uses for threads. I've used it for years on every Okuma I've needed to make parts on from 5000L controls to today.
    The format is this:
    G0 X1.3
    G71 X1.1234 Z-2.3456 H[1.3-1.1234] D.01 B60 U.0005 F1/18 M33 M73
    G0 X30 Z30
    X: target X end point (not quite theoretical minor diameter but that's usually where I start)
    Z: target Z end point (will depend on how you touch off your tool)
    H: Thread height (where how tall the thread is so it knows where to start taking cuts from)
    D: Depth of cut for first cut (all other cuts will be similar/calculations of this number depending on M codes: M33/M73 M34/M74 or whatever you use)
    B: thread angle (60 degree thread, B=60 so on)
    U: Finish pass allowance for last thread pass
    F: feed rate listed as threads per inch because it's easy to see that's an 18TPI thread as opposed to F.0555
    (A value is available in case the threads are tapered)
    (I value can be used for tapered threads)
    (L value for chamfering at end of thread)
    (E value for thread lead variation)
    (J in case you use a combo of F/J for thread callouts. Useless in metric mostly)
    (Q for multi lead threads)
    M codes
    The book details what the combinations of these do
    I've never met any Okuma guy who prefers to use G33 over G71 for any other reason than continuity from Fanuc code to Okuma code.
    But whichever floats your boat.
    I'm just saying that G71 is no less capable for 99.9% of the work I've seen and I challenge you to show me a part that this is different.
    I did do a test once to prove this on an LB machine where my operator swore by G33. I coded it the way he wanted it and it tool longer to cut threads and he had more issues to the point that by the end of the day he said these words in this order:
    "Well that didn't work. I guess we'll stick to G71."
    Just because you hear hooves doesn't mean it's a zebra every time.
    Sometimes, it's just a damn horse.
  11. #31
    Jun 2015
    4154
    i am not making it difficult, i avoid it
    teahole ... no, not like this i did not said that others can not cut tight tolerances i would not say it not even as a joke
    well, besides cases that i encounter, i can tell this about others :
    ... there had been cases where G71 did not work for others, and needed to use G33
    ...... onestly, i also think this way, because G71 has its own mind, and is easier to generate what you wish with G33 instead of tweaking the G71
    ....... real case : conic threads
    ... there are persons that check if G71 and G33 can work one after another, thus their codes deliver identical spirals in space
    ....... real case : comparing cnc capabilities between different control generations
    ... there are persons that use G71 in a single-shot mode, just like G33
    ....... real case : after threading, need to recut cilinder and repeat finish
    at this moment only this cases i have remembered
    obviously, those are not common cases ... but they are not strange, or should i say those are not forced cases, only to put G71 in a bad light and also i dont say that G71 could not do it
    not quite ... i dont program only to get floating is about full control path with shortest programing time that i can deliver
    all i can say is that it started because of some dimensions, briefs and control that i could not understood back then, and at this moment it became predictive ... thus i can compute out-of-charts tolerances, and so on
    i will share when it will be ready
    there is an image attached :
    ... left : can G71 generate code regardless of point positions inside the section ?
    ... right : can G71 generate infeed evolution as desired ?
    G71 uses inner paterns, and sometimes this patterns are a headache
    this does not mean that the answer to those questions is no ... but a better answer is G33
  12. #32
    Aug 2017
    16
    Thanks for the help everyone I was able to make the G71 work in this instance we are only threading really simple pins for this application and I appreciate the help
  13. #33
    Jun 2015
    4154
    hi newton / G71 delivers in most cases
    what your CAM delivered is a more versatile approach, that maybe one day you will find it usefull
    is good to know what the Okuma control can do
  14. #34
    Apr 2016
    74
    Quote Originally Posted by deadlykitten View Post
    deadly,
    you really need to look at who is asking the question, if someone is new to this, why overload them with all that info.
    he was looking for a simple solution.
    I happy that you have all that knowledge, but look at the student better.
    also i must say when it comes to threads use the "kiss" method is always a good thing.
  15. #35
    Jun 2015
    4154
    hy walker i did not know what this guy was expecting, and my guess was that he needed help with his code
    somewhere i felt that mr newtoon had falled into a trap
    you know : click+save ! whats thaaaat ? it does not work ... help
    mr Wizard, which is more experienced, also suggested using rapids when positioning & other stuff
    teahole also showed up ... his presence is rare, but concentrated
    well, all is good when it ends with G71
  16. #36
    Jun 2015
    4154
    each one with his own kiss
  17. #37
    Apr 2016
    74
    Exactly,
    always good to hear from you!
    I am dealing with a guy here right that say's what?? all the time.
  18. #38
    Jun 2015
    4154
    i am a bit tired to give an answer to that i will reply when thunder strikes
  19. #39
    Jun 2015
    4154
    here are some trials :
    Code:
     6x    260 240 210 160 110  50
     5x    285 265 235 185  60
     5x    310 290 240 130  60
     9x    180 170 160 140 100 100  80 50 50
     9x    180 170 160 150 140 100  50 40 40
    10x    240 200 160 120 100  80  40 30 30 30
     9x    270 210 170 150 100  40  30 30 30
    11x    160 150 150 140 120 100  80 40 30 30 30
    12x    120 120 120 120 120 120 100 80 40 30 30 30
    similar inserts from different producers have significantly different quality for the cutting edge
    such things i run and test pas-by-pas, by taking a look at chip aspect
    chips must not be burned, and should not remain on the tool
    as a result :
    ... cutting edges last much longer
    ... thread aspect increases
    ... number of tool corections reduces
    ... rpm can be increased
    setup becomes more stable at current specs, thus permitting to increase specs
    after a high point is reached, increasing specs even more will deliver less quality parts
    there is a difference between [ any carbide inserts on any lathe ] vs [ quality carbide inserts on Okuma ]
  20. #40
    Sep 2010
    1230
    deadly,
    Hello kywalker4,
    This Dumbo has been inflicting himself on Practical M for some time now. His apparent knowledge on the surface has been shown to be a profound lack of knowledge in reality. Empty vessels make the most noise.
    Regards,
    Bill
Page 2 of 3 123
  1. okuma osp u10l
    By TOMO1 in forum Post Processor Files
    Last Post: 08-03-2017, 01:44 PM
  2. okuma OSP-U10L
    By clayd-cnc in forum Okuma
    Last Post: 09-20-2016, 10:51 AM
  3. Post for Okuma Osp-U10L
    By Pupc in forum Post Processors for MC
    Last Post: 04-01-2016, 02:56 PM
  4. Okuma-U10L DNC
    By hense in forum Okuma
    Last Post: 04-25-2009, 07:23 PM
  5. OKUMA OSP-U10L RS232
    By edmondyjh in forum Okuma
    Last Post: 01-28-2009, 08:27 PM
