585,748 active members*
3,614 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Rigid tappin, Fanuc 15m on Femco boring mill
Results 1 to 8 of 8
    Aug 2016
    15
    Hello. Was hoping some could help me figure out how rigid tap on a Fanuc 15m on a Femco boring mill. According to the Fanuc 15m user manual, it say G84.2 is for right hand rigid tapping, but when I tried it, the machine gives me a invalid G-code alarm. Any help trouble shooting this would be appreciated.
    Dec 2012
    395
    Re: Rigid tappin, Fanuc 15m on Femco boring mill
    Add these lines in your program and run/test it on a safe Z-height.
    Metric tap M10x1.5,
    G95 ( MM/REV )
    M29 S500
    G84 Z-15. R3. F1.5
    X-- Y--
    X-- Y--
    G80
    G94 ( MM/MIN )
    Regards,
    Heavy_Metal.
    Aug 2007
    793
    PM sent
    Aug 2016
    15
    Thank for the replies. I'll try these suggestion when I get around to powering the machine back on.
    :rainfro:
    Aug 2016
    15
    Quote Originally Posted by Heavy_Metal View Post
    Metric tap M10x1.5,
    G95 ( MM/REV )
    M29 S500
    G84 Z-15. R3. F1.5
    X-- Y--
    X-- Y--
    G80
    G94 ( MM/MIN )
    Regards,
    Heavy_Metal.
    The Fanuc 15m programing manual dose not mention the use of M29 for rigid tapping. I know M29 is use on the Fanuc '0' & '18' series control. It is my hunch that the rigid tapping option is not turned active on this machine.
    Dose any know the proper code for rigid tapping on a Fanuc 15m control and the alarm generated if rigid tapping is not installed on the machine. I perfectly fine if this option is not turned on. I just want to be able to use the rigid tapping if it is enable on the machine.
    Dec 2012
    395
    Do you have the Fanuc 15-MB with the B62564E Operator's Manual.
    If so, pages 207 - 215 are about Rigid Tapping G84.2 and without the M29.....!
    Check also your personal message.
    Regards,
    Heavy_Metal.
    Aug 2016
    15
    Quote Originally Posted by guhl View Post
    PM sent
    Thank you Guhl. with the information you provide me, I was able to conclude that the Rigid Tapping option was not enabled.
    I am really sorry to hijack this thread but I am really desperate.
    I have a femco wbmc 100r2 fanuc 15M and I lost the parameters and we have no backup. If any of you have a similar machine with the same control and brand name then it might work even if is not the same model. If some one has the same machine then I can and I am willing to pay.
    Please email me to [email protected], that is [email protected]
    www.doctornumerico.com
    cnc physicians
  1. Replies: 0
    Last Post: 07-02-2015, 05:20 PM
  2. Rigid Tapping on floor boring machine.
    By SatishNaik in forum News Announcements
    Last Post: 07-29-2013, 01:08 PM
  3. Replies: 0
    Last Post: 07-24-2013, 07:03 AM
  4. FANUC 0T FEMCO DURGA 25E
    By saul in forum Fanuc
    Last Post: 05-20-2013, 10:29 PM
  5. Drill cycle on a Fanuc 11m control in a Kuraki boring mill
    By fred norris in forum G-Code Programing
    Last Post: 06-09-2011, 02:04 PM
