585,925 active members*
3,308 visitors online*
Results 1 to 17 of 17
    Jun 2012
    125
    Need more inputs, Parallel Port. Ideas
    Hey guys,
    I've run out of inputs for my Parallel Port break out board. 3 axis with 2 motors and sensors on one axis (4 inputs), E-Stop and I'm out. I only want one more for tool touch off sensor. Easiest thing I can think of is adding another parallel port and break out board which will give me plenty but I'm wondering if anyone has an idea just to get a cheap extra one input?
    Should add, I'm more than happy with the performance of the Parallel port. Just lacking an input. The break out board is super cheap for what it does too.
    Happy Days.
    Re: Need more inputs, Parallel Port. Ideas
    Arduino and modbus, but imo the parallel port is easier.
    May 2005
    3920
    If you need just one port, one that doesn't need to be high speed, you could always use a handshaking pin on an RS232 port. Of course this depends upon having can RS232 port to exploit. Further you would have to write your own code to monitor the port. I've actually done this on the out going side to control an optical isolator for a project. Fully compliant RS232 ports drive at about 12 VDC with enough current to toggle an optical isolator. Sadly on laptops you often don't get compliant ports even if they are physically there.
    The biggest problem here might be speed, I was using Python at the time and controlling the port with a high level library so really have no idea if the tis fast enough for anything you might want to use.
    A second option would be to program an Arduino as an I/O device ideally plugged into an isolated digital I/O board. Arduinos are dirt cheap and as such cost effective enough even for single bit I/O.
    The third option of a parallel port board isn't bad at all. These can also be found dirt cheap especially for older I/O buses.
    A fourth option would be to use an FTDI solution: USB to RS232/422/485 Modules for RS232 adapters or some of its chip sets which may support parallel I/O.
    Jun 2012
    125
    Thanks for the info guys. It gives me somewhere to start looking. I'm using LimuxCNC. It seems Mesa boards are hugely popular with Linux but also cost. Apart from one extra input, I don't know why you spend so much extra money.
    May 2015
    686
    Quote Originally Posted by joel0407 View Post
    Thanks for the info guys. It gives me somewhere to start looking. I'm using LinuxCNC. It seems Mesa boards are hugely popular with Linux but also cost. Apart from one extra input, I don't know why you spend so much extra money.
    For small machines, there is nothing wrong with a parallel port and adding a second one is a good option. If you are running servos then you have to either go with pico or mesa or a couple of others. For plasma, Mesa is a no brainer. Think about it. Ethernet to keep the PC away from the noise, a USD $69 torch height option and 16 outputs and 32 inputs (which I think I have used 31 of) Not to mention 5 stepgens that blitz par port performance, some A/D inputs, 2 MPG inputs plus virtually infinite expansion. It is a pretty amazing ecosystem and once you buy into it, you'll never want to go back.
    Rod Webster
    www.vehiclemods.net.au
    Jun 2012
    125
    Quote Originally Posted by rodw View Post
    I don't know how popular servos are? From what I've read they aren't all that popular.
    Comparing a second hand PC for $25 and a parallel break out board for $12 (or close to, can't remember). I think you mentioned to me before that it's easy enough to run a remote terminal to the PC running the router. So it's not that hard to have separation from your main PC. For $37 it's a bloody cheap option. I'm keen to post a video of my machine once it's finished because I think it's bloody fast. I'm wondering what's the point of the super stepgen performance?
    Happy Days.
    May 2017
    31
    Hey guys,
    Happy Days.
    Can't you share an input pin for two of the limit switchs the Z axis and any other one?
    Jun 2012
    125
    Quote Originally Posted by Tutu View Post
    All the limit switches are in series with the E-Stop. so only one input for all the limits. Each axis only has one homing sensor. I guess where my setup is a little less common is I have 2 screws and 2 motors on my Y axis. That means I need 2 homing sensors for that axis to square itself when it homes.
    Happy Days.
    May 2017
    31
    Happy Days.
    That's pretty common it's how mine is setup share homing input pin Z and X you only need individual pins for homing on the Y axis.
    I have no Z homing switch so only need 3 inputs anyway.
    Apr 2013
    1899
    Happy Days.
    What's the point of having a home switch on Z? Disconnect tha and use the input as probe. Or add another parallel port. These are the cheapest and simplest options.
    1943
    Sounds like you have dedicated homing sensors in addition to limit switches. Since in this case the homing switches are only used for homing, it may be possible to use the same pin for the homing sensor and a probe either in parallel or series as appropriate. I believe that this is possible in LinuxCNC and would get around needing another PP.
    As for why a home switch is needed for Z, I can't speak for how others operate, but as an example:
    If I discontinue machining a part for the night or whatever, I shut down the machine and then when I come back the next time, all I have to do is turn the machine on, home, and resume where I left off. If I didn't have a Z axis home switch I would have to touch off to re-establish my Z-zero before machining. If using multiple tools and the break in the action is not during the use of tool #1 then I would have to re-insert tool #1 touch it off and then go back to whatever tool was the current one. This is because I use tool #1 as the baseline too and the tool lengths of all other tools are relative to the length of tool #1. With Z-axis homing none of this is necessary.
    Another reason for z-axis homing in my opinion is because it sets the envelope of the Z-axis. Without homing the Z, things like the G28 or G30 positions are not consistent among other things.
    Jun 2012
    125
    Quote Originally Posted by 109jb View Post
    Now this is interesting. I might have to do a little reading. I think you are right. I can set the same pin for both. The difference will be the direction of movement for each action. I'd need to move Z off home prior to touching off. Since my homing senor is a proximity sensor, Z approaches home at a higher speed, trips sensor, backs off slightly then approaches at a slow speed for better accuracy. Once tripped, Z will proceed past the sensor for a predetermined distance. I'd need to back off home until the sensor was released then touch off.
    I like it. I'll give it a go. Might confuse things but worth a try.
    Happy Days.
    May 2017
    31
    Happy Days.
    Maybe I'm not understanding so forgive me if I'm wrong but you have 5 input pins if like my board.
    X,Y, Z, touch sensor, Estop is how mine were labelled
    lets assume your dual ballscrew is the Y axis.
    plug the X & Z home switch into the X, plug one of the Y home switches into Y and the other into Z, leaving you enough pins for everything else
    Then setup the X&Z share an input and your Y axis homing and your done.
    1943
    He has:
    1. All limits + E-stop
    2. Y1 home
    3. Y2 home
    4 . X home
    5. Z home
    So, yes he could possibly combine the X and Z home switches on one pin and thereby free up the other pin for a probe.
    Jun 2012
    125
    I'm not really understanding how I can combine the X and Z axis switches. I thought possibly you meant using a NC switch on one and NO on the other but I still couldn't think of a homing sequence that would work.
    May 2017
    31
    It's easy when you know how
    what it does is touch the X axis first when homing knowing it moved the X axis it know that input must be X home. Then it steps away from the Axis and homes the Z axis now knowing the input must be the the Z because X is parked off it's switch.
    You can configure order, parking position, etc. The biggest disadvantage is you can only home one axis at a time buit for most people this is a non issue.
    Using 1 switch NO and one NC will NOT work!!!!!!!
    1943
    If you have NC switches, wire them in series to one input and assign that input for X home and Z home. If you have NO switches, then wire them in parallel. As said, one NO and one NC won't work.
    When you activate the homing sequence, neither the X or Z axis home switches are activated. The Z-axis homes by itself, trips the switch, and then backs off of the switch a little bit. Then the X-axis homes. Since the Z-axis had backed off, neither the X or Z home switches are activated when the X starts its homing process.
    The "standard" homing sequence is Z by itself, followed by X and Y simultaneously. For your setup this should work fine, but with 2 Y axis motors, you may want to do each axis individually. If the standard sequence works it would just mean there are 3 motors homing at the same time. In linuxcnc, you can set up homing to do whatever you want.including order, how much it backs off, what the machine coordinates are set to when done, etc.
  1. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  2. no new computers have parallel?? experience on adding parallel port yourself?
    By teglberg in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2014, 07:18 PM
  3. parallel port
    By lucky021 in forum Canadian Club House
    Last Post: 05-02-2010, 07:42 PM
  4. USB to Parallel port??
    By willio in forum Shopmaster/Shoptask
    Last Post: 11-12-2009, 09:42 PM
  5. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
