585,930 active members*
3,550 visitors online*
Results 1 to 3 of 3
    Apr 2017
    5 axis head bearings
    Hello,
    i have just completed a linear 3 axis portal milling machine and am now designing the rotary b and c axis. (head design)
    However i have problems to figure out or too find which bearings i need for this application.
    So far i could come to the conclusion that i would need crossed roller bearings. Those seem pretty expensive and not that common available in any shape and size.
    So i ask myself if there are any other solutions that i could choose from. Surely there has to be some or not?
    I would be glad if anybody could help me a bit out.
    I know that i need some gearings in advance.....
    My point is what bearings do i need?
    I dont want to mill steel or metal.... just styrofoams and wood.
    Greetings
    CNCImpulse
    Jul 2017
    8
    Re: 5 axis head bearings
    If 5 axis wood router just try Japanese NSK bearings
    Jun 2010
    4256
    Crossed roller bearings (CERBs) would be the ideal solution. Yes, they are $$, but so is any 5-axis machine.
    The next best solution would be double angular contact bearings (ACB), shimmed to the correct preload. More engineering, for slightly less $$ outlay.
    The brand of the bearings does not matter as long as they are good ones. But then, I am not sure you can buy Chinese CRBs. (You can get Taiwanese ones from Hiwin ... not actually Chinese.)
    Cheers
    Roger
  1. Replies: 1
    Last Post: 03-20-2015, 01:52 PM
  2. Build double head laser with motorized x axis on each head
    By amders in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2015, 02:41 PM
  3. Grizzly (G8688) 7x12 Head Stock Taper Bearings
    By Danny X in forum Mini Lathe
    Last Post: 05-27-2011, 10:05 AM
  4. Obsolete Norma bearings...J head
    By tom in nh in forum Bridgeport / Hardinge Mills
    Last Post: 03-10-2009, 12:57 AM
  5. J-Type head spindle bearings?
    By GalaticDan in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2006, 03:36 PM
