585,956 active members*
4,381 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Suggested materials to use for laser cutter's outer and interior walls or panels
    Aug 2017
    I'm building an 80W Co2 laser cutter bottom up from scratch. Actually It is nearly done and is operational right now, but it is still just an open aluminum extrusion framework. It needs an outer covering and interior walls for safety and air flow reasons of course. I really like the transparent look both for show and being able to see what is going on inside. I would love to just use clear acrylic sheets for every surface. Am I crazy if I do that? I don't see any homemade Lasers that are fully transparent online so maybe that means I am a genius or insane. :-) What materials do most people use for these panels on their builds? I am trying to avoid steel plates because I lack the tools to cut that. I'm hoping for more acrylics or woods etc. Looking forward to hearing your ideas! Thanks!
    Here's a picture of it which I'm sure always helps. :-P
    Re: Suggested materials to use for laser cutter's outer and interior walls or panels
    Good idea.
    But acrylic cover is not complete safe for laser.
  1. Mixed laser cutter for thin metal and thick non-metal materials
    By stylecnc in forum News Announcements
    Last Post: 04-18-2016, 01:45 PM
  2. Replies: 0
    Last Post: 01-07-2016, 08:41 AM
  3. Automotive Interior Usage-OMNI Laser Machine
    By omnicnc in forum Omni CNC
    Last Post: 03-12-2014, 07:44 AM
  4. How to laser cut solar panels and set focus
    By funidea in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2009, 06:25 PM
