So we bought this machine knowing it needed work, it is a very large Mitsubishi horizontal boring mill. So we got it back together now and the mpg handle didn't work so I had meau tech check it out and found the cable was bad , they also re zeroed and cleared another code e51 file open.So now the spindle will not run, it gives code t02 204 feed hold,push feed it says t01 104 cycle can't start.It will orient with m19 and it will shift in to high or low gear depending on rpm commanded also the . Checked feed hold switch and checked good.Tech says maybe machine side problem machine builder Mhi says maybe control side problem
