585,705 active members*
3,909 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Romi Lathes > romi centur 35e with duplomatic BSV n 160/8 and Fanuc o-t
    Jan 2007
    11
    I am in need of wiring schematic for a Romi Centur 35E with a Duplomatic BSV N 160/8 position tool turret and a Funuc o-t control 1992
    I am having trouble with the tool turret indexing it appears electrical ( wires have been cut and spliced ) , the stop pin is not firing during automatic control ( it is 24v and works when connected to power and ground ) need to find witch relay to test / replace or if it is a logic problem.
    the coil has 24v constant and the relay closes to ground , but the relay it is connected to does not activate during the tool index cycle , the relays have green led when active , I can see three relays that activate during the index cycle , but the stop pin coil is not connected to any of them.
    Jul 2014
    11
    Encontrou algum documento ? [email protected]
    Oct 2009
    6
    Re: romi centur 35e with duplomatic BSV n 160/8 and Fanuc o-t
    Hi, i have the schematics in paper, i can take pics for you. Do you have a backup of this machine?
  1. NEED HELP: ROMI CENTUR 35E
    By jschmid in forum Bridgeport / Romi Lathes
    Last Post: 07-24-2017, 12:08 PM
  2. Romi/Bridgeport Centur 35 lathe
    Last Post: 03-24-2014, 07:05 PM
  3. Romi Centur 35E Lathe
    Last Post: 06-04-2013, 03:20 AM
  4. bridgeport romi centur 35 e 090 P/S alarm
    By sdconcepts in forum Bridgeport / Romi Lathes
    Last Post: 03-06-2013, 05:04 PM
  5. fanuc 21i-t on romi lathe
    By jposey3 in forum Fanuc
    Last Post: 09-24-2009, 06:42 AM
