585,599 active members*
3,647 visitors online*
Results 1 to 6 of 6
    Jun 2017
    32
    C62 setup question
    Bought new c62 recently - getting to setup and all the wonderful manuals error 404.
    Anyhow, setting up c62 board with KL2283 drives. Possible to identify which wires from rj45 out goes to dir- / dir + / pul - / pul +? Thanks
    Re: C62 setup question
    Contact Arturo, and let him know that his website is messed up, and you need a manual.
    Jun 2017
    32
    Finallly got in touch with them via their site - they helped and they will.
    The idea is that you connect that driver using the C34KL:
    https://cnc4pc.com/c34kl-driver-to-r...s-drivers.html
    If you do not have it, you could connect it using the pinout on page 15 of the manual of the C62:
    http://cnc4pc.com/Tech_Docs/C62R5_USER_MANUAL.pdf
    Connect PUL- and DIR- to GND and STEP and DIR pulsed on the C62 to PUL+ and DIR+.
    I am sorry for the manuals folder in our website, it is OK now.
    Arturo Duncan
    Welcome to CNC4PC
    Jun 2017
    32
    Wish I had known that existed before now. Dang.
    Thanks for response - cnc4pc support has always been helpful. Glad site / manuals are back up
    Edit - just ordered 3 of your adapters. should make install look nice as well as perform. Great idea. Consider making adapter like that for common VFDs?
    Jun 2017
    32
    As FYI - received adapters today, the C34KL does not fit the KL2283 driver. Pins are too wide, does not match the inputs. Figure it would be same for the 1180 model.
  1. question of Setup
    By jarl85 in forum Cincinnati CNC
    Last Post: 02-01-2017, 03:08 PM
  2. Anyone help with a setup question?
    By jaysteel in forum Machines running Mach Software
    Last Post: 02-06-2009, 05:18 AM
  3. Setup Question
    By tikka308 in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2007, 04:45 PM
  4. Setup Question
    By buddym in forum DIY CNC Router Table Machines
    Last Post: 11-19-2006, 02:52 PM
  5. Another Setup Question...
    By rcazwillis in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-04-2005, 03:55 PM
