585,578 active members*
3,784 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Feb 2007
    1538
    4th AXIS SET UP AND RUN PARTS
    Hi Folks. All is well in my neck of the woods, just a bit too busy...
    Here is a video of setting up the 4th axis and running parts - feel free to post your 4th axis related information.
    Cheers Cliff
    https://www.youtube.com/watch?v=Bw6VqaHH3uk
    Aug 2013
    980
    Nice video, thanks.
    Have you ever used the 4th axis homing probe tormach sells. It use to work great with Mach but not so well with path pilot.
    Quote Originally Posted by keen View Post
    Cheers Cliff
    Feb 2007
    1538
    Re: 4th AXIS SET UP AND RUN PARTS
    "Nice video, thanks.
    Have you ever used the 4th axis homing probe tormach sells. It use to work great with Mach but not so well with path pilot."
    Thanks - No I do not have a 4th axis home set up - so far I have been able to run the parts before shut down and so have not needed a rotary orientation reset on start up.
    I assume that is the main use for it? Cheers Cliff
    Aug 2013
    980
    It us useful for me when flipping parts.
    Jun 2012
    311
    I have the 4th axis home set up but haven't used it. One of the reasons to use it is so you don't have to "unwind" the axis after a long spiral cut. i.e. if the cut starts at A0 and does 6 revolutions to A2160 then goes back to A0 for the next pass, it will take a minute or so for the A axis to unwind. Re-homing the A-axis after each pass eliminates that.
    Feb 2007
    1538
    I was wondering if there is a G Code/software script that you can install in the code that will change an axis position - eg on reaching A2160 reset the DRO to A0.00...that would be useful.
    Cliff
    Dec 2008
    740
    Cliff
    Hi Cliff
    I ran into this issue on my very first 4th axis part. I had to wait 20 minutes for the A axis to return to A0
    I solved this in my Sprutcam post but that probably won't help you, but it can be done in G-Code. I just tried this out quickly and it appears to work:
    Code:
    G10 L20 P[#5220] A[#5423-360*ROUND[#5423/360]]
    G0 A0
    The first line unwraps the A axis by subtracting as many whole turns as necessary to get the machine coordinates within 180 degrees, and the second line should need no explanation.
    I suspect someone might have a more elegant equation but I couldn't find many functions that are supported by g-code.
    Try it out before you use it to make a part!
    Step
    Aug 2013
    980
    You can. just type in 'G0A0' in the DRO and the 4th will return to zero. Thanks
    QUOTE=keen;2080600]I was wondering if there is a G Code/software script that you can install in the code that will change an axis position - eg on reaching A2160 reset the DRO to A0.00...that would be useful.
    Cliff[/QUOTE]
    Nov 2007
    2151
    Quote Originally Posted by CadRhino View Post
    Nice video, thanks.
    I tried to get the hal sensor to work on my super spacer and path pilot. It seems to work but I think my sprutcam code still unwinds the axis and as mentioned above it takes time.
    Need to do a little snooping and hacking now that I read tsteps post.
    BTW Keen you make some nice looking parts . I need to add a electronic probe system to my crib. Just looks like a fun tool to use and impress the neighbors.
    Adding to this discussion I use a 5c collet holder in my 8" super spacer chuck for small parts. Holds the material away from 8" chuck, very rigid and when I sweep the faces / edges of material or part they align well and easy to adjust. That said a tormach 5c 4th axis holder would be the best solution if its easy to align on face plate.
    Feb 2007
    1538
    [QUOTE=CadRhino;2080762]You can. just type in 'G0A0' in the DRO and the 4th will return to zero. Thanks
    Thanks for posting CR - But if you type in G0A0 it just commands the A axis to mechanically wind to that point? I mean I want a auto 'software position' conversion in the code. Cheers Cliff
    Feb 2007
    1538
    Quote Originally Posted by TurboStep View Post
    Hi Cliff
    Code:
    G0 A0
    Step
    Thanks Step ! You know your stuff! I would like to try that. Please would you reply with the exact code for me to enter at the end of my job G code. My code starts on A0 and ends on A270 - but then slowly winds back to A0 at the next run of the code of course. I would like the A270 position to become A0. Would you be able to give me the exact code to insert please.
    Cheers Cliff
    May 2016
    316
    Cliff,
    Assuming you are working the part in G54 offset, then I think the code you append at the end (or beginning) of the run should be:
    G10 L2 P1 A0
    G0 A0
    If you are working the part in G55, then the P-number will be "2"
    Taken from Tormach's page on G-code:
    To set the coordinate values for the origin of a fixture coordinate system, program:
    G10 L2 P~ X~ Y~ Z~ A~, where the P number must evaluate to an integer in the range 1 to 255 – the fixture number (Values 1 to 6 corresponding to G54 to G59) – and all axis words are optional. The coordinates of the origin of the coordinate system specified by the P number are reset to the coordinate values given (in terms of the absolute coordinate system). Only those coordinates for which an axis word is included on the line will be reset.
    It is an error if:
    • The P number does not evaluate to an integer in the range 0 to 255.
    If origin offsets (made by G92 or G92.3) were in effect before G10 is used, they will continue to be in effect afterwards. The coordinate system whose origin is set by a G10 command may be active or inactive at the time the G10 is executed. The values set will not be persistent unless the tool or fixture tables are saved using the buttons on Tables screen.
    Emphasis mine on the last sentence. I don't use or know PathPilot, so of course please prove this out in a non-expensive way prior to production work. You could insert that bit of code at the beginning of the program, and it'll be like pressing the A-axis 'zero' button.
    Regards,
    Spumco
    Feb 2007
    1538
    Hi Spumco - most appreciated. Yes I am in G54. Today I tried G10 L20 P1 A0 at the start of the code and it worked a treat.
    I only half understand this stuff - but now I know what to do! The A reset from A270 at program end, to A0 at program start.
    Thanks for your input. Cheers Cliff
    Feb 2007
    1538
    Quote Originally Posted by mountaindew View Post
    Thanks - Yes I should get a 5C holder of some type also. Cheers Cliff
    Nov 2007
    2151
    Mentioned this because 5c or any collet and holder combo is my favorite part / material / tool holding system. I find I can load material into a 5c / holder and have my way with it on both a 4th axis and a vise on the table at same time. Start with vise and do vertical machine operations then slide into jaws on 4th axis with work stop to repeat and perform all the rotary operations then move back to vise for cut off or other ops. Setup all the offsets one time for first part then repeat for as many as I want make
    Side note
    In the past looking at pictures of machine shops and walking thru a few. I always wondered why some had hundreds of collets and sets of different sizes. I always figured it was to hold different tools. I understand now I have 2 sets of holders, 2 sets of the same size common collets and drawers full of other sizes and shapes and even a few soft collets like soft jaws
    Apr 2013
    1788
    [QUOTE=keen;2081006]
    I suspect that he meant to set the A-axis DRO to zero rather than entering g0a0 in the MDI window. Here g0a0 unwinds while setting A-axis to 0.000 completes instantly. I have not yet tried steps suggestion. Note that the unwind problem is not specific to spurt but occurs with hand coded programs.
    Dec 2008
    740
    Quote Originally Posted by spumco View Post
    G10 L2 P1 A0
    G0 A0
    The parameter #5220 (see my earlier post) represents the current coordinate system so the following line will be valid irrespective of the coordinate system in use:
    G10 L20 P[#5220] A0
    Once this has been called PathPilot will believe it's already at A0 so there's no need to call G0 A0 afterwards.
    Step
    May 2016
    316
    Step,
    I thought that might be the case, but I don't know PP and I figured if Cliff was testing it and my suggested G10 L20 xxxx didn't work for some reason he'd see the A-axis move at the G0 line. That would have been a good indicator that all was not well.
    Now that it's proven to work as he wants, Cliff can forego the superfluous G0 A0 block for 'real' programs.
    Your code is obviously more elegant than having to pick a particular coordinate system, but it's possible that Cliff didn't know or recognize the parameter #5220 (neither did I!) and assumed that was something specific for your system. I know I didn't have a clue what it meant.
    Thank you. I'm constantly - pleasantly - reminded why I lurk in the Tormach forum despite not having a Tormach or even using PathPilot.
    -S
    Nov 2007
    2151
    G10 L20 P[#5220] A0
    Step
    Step,
    -S
    I would like a link to more info on this subject "parameter #5220" I use the hal homing system Tormach sells. It still rewinds so I need to add this to g code or im doing something else wrong.
    Thanks for any help in advance!
    Dec 2008
    740
    Hi MD. If you're using the homing kit and home the A axis I wouldn't expect the 4th axis to rewind any further than the homing sensor (I don't use the sensor so I can't test this assumption). However if you enter A0 it will continue to rewind until the initial angle has been covered i.e. if the A DRO reads 3600 degrees the axis will rotate 10 times until A0 is reached. The homing switch should play no role in this.
    The G-code I provided in post 7 should eliminate the unnecessary whole rotations, leaving no more than a half rotation to zero.
    Code:
    The #5220 isn't the most important parameter here. It simply represents the current coordinate system i.e. '1' for G54, '2' for G55 etc. If you're working in G54 you could simply use a '1' instead:
    Code:
    G10 L20 P1 A[#5423-360*ROUND[#5423/360]]
    The parameter #5423 represents the current A position. The equation is actually very simple. If the current A position is say 3636 degrees (10 full turns plus 36 degrees) the division on the right would divide this value 3636 by 360 giving 10.1. Then ROUND rounds to the nearest whole number giving 10 exactly. Multiplying this rounded result with 360 gives 3600 degrees which is subtracted from the original value of 3636 to give 36 degrees. G10 L20 sets the A position to the result of this calculation i.e. 36 degrees - just like entering this value in the DRO. The A axis hasn't moved yet. Commanding A0 now only needs to rotate the A axis by 36, instead of 3636 degrees.
    If this code is used in a subroutine or a post processor you'll have to ensure that the current coordinate system is used - which is where the parameter #5220 comes in handy.
    If you enter a large number in the A DRO and type or copy/paste this line of code in the MDI you should see what happens.
    I hope this has clarified something (a little?).
    Unfortunately I haven't found a way of automatically adding a line of code like this within a Sprut program without modifying the post. The Auxiliary INSERT almost works, but it doesn't add the line number.
    Step
Page 1 of 2 12
  1. FS: CNCRouter Parts Pro Z Axis
    By FoxCNC1 in forum For Sale Only
    Last Post: 06-10-2017, 01:02 AM
  2. Most intricate parts possible, 3 & 4 axis
    By tbev in forum Tormach Personal CNC Mill
    Last Post: 08-22-2016, 05:50 PM
  3. Parts needed for CNC Router 6.6ft x 10ft 3 axis. Also optional big Z axis.
    By bajlekov in forum Uncategorised WoodWorking Machines
    Last Post: 06-26-2014, 10:12 AM
  4. Replies: 32
    Last Post: 10-27-2013, 04:30 PM
  5. Z axis build using CNC Router Parts.
    By niner_zero in forum Avid CNC
    Last Post: 09-15-2013, 03:49 PM
