584,854 active members*
4,245 visitors online*
    Jul 2017
    12
    Mach3 reading fusion 360 g-code as error
    i' a newbie in programming i used fusion 360 to make a sketch and generate g-codes.
    when i run it to Mach3 it read a lot of errors. part of the g-code below in red print are the error and message
    Please help me how to correct this errors. Thank you
    : (PGM, NAME="1001") message of mach 3 ver 2 Bad charcter, Block = : (PGM,NAME="1001"
    ; T1 D=0.25 CR=0 - ZMIN=0.7697 - FLAT END MILL
    : G90 G40 G94
    G17
    G70
    M26
    ; POCKET1
    M9
    M26
    :T1 M6
    M26
    S10000 M3
    H0
    M9
    G0 X2.3957 Y2.0816
    Z1.9462
    Z1.6412
    G1 Z1.6288 F30
    X2.3959 Y2.0811 Z1.6234 F60
    X2.3966 Y2.0794 Z1.6182
    X2.3977 Y2.0768 Z1.6135
    X2.3993 Y2.0734 Z1.6096
    X2.4014 Y2.0693 Z1.6066
    X2.4039 Y2.0648 Z1.6046
    X2.4067 Y2.0602 Z1.6038
    G17 G3 X2.435 Y2.03 Z1.6024 I2.5062 J2.125 K0.0261 Keyword given for arc in xy plane, Block = G17 G3 X2.435 Y2 etch
    X2.5775 Y2.22 Z1.5894 I2.5062 J2.125 K0.0261
    X2.435 Y2.03 Z1.5763 I2.5062 J2.125 K0.0261
    X2.5775 Y2.22 Z1.5633 I2.5062 J2.125 K0.0261
    X2.435 Y2.03 Z1.5503 I2.5062 J2.125 K0.0261
    X2.625 Y2.125 Z1.5411 I2.5062 J2.125 K0.0261
    Re: Mach3 reading fusion 360 g-code as error
    Make sure to use a Mach3 post processor.
    Jul 2017
    12
    Sir ger21
    thank you i appreciate it. it works.
    i set it to mach3 before it was at acromatic.
    now i'm in "tap" extention.
    thank you
  1. alphacam file reading error
    By fazzahughes in forum Alphacam
    Last Post: 10-02-2017, 12:15 PM
  2. Mach3 RPM reading
    By Stoneman40 in forum Australia, New Zealand Club House
    Last Post: 05-18-2016, 02:40 AM
  3. Replies: 3
    Last Post: 04-23-2015, 08:19 PM
  4. error reading xml
    By dlaery in forum BobCad-Cam
    Last Post: 01-05-2013, 12:01 AM
  5. Plasma G-code reading
    By silon132 in forum Waterjet General Topics
    Last Post: 10-30-2008, 01:45 PM
