584,805 active members*
5,276 visitors online*
Results 1 to 13 of 13
    wisconsinjimmy Guest
    Convert jpeg to svg for MK3/4
    Hello and hope I am in the right area, there is a youtube video by the old geezer? on how to convert clip art to svg using Inkscape and MakerCam. I have followed him on how to do it and it works slick but when I try to take a jpeg file and convert to svg things go terribly wrong. When I open the file in Inkscape I am supposed to left click the picture and move it to the left then go back and delete the original but when I move the file to the left I am left with nothing.
    What I need to know is how do I take a scanned jpeg and turn it into a svg and then to G code, I do wood working and would like to make this machine work.
    Jim-WI
    Re: Convert jpeg to svg for MK3/4
    Anyone?
    Am I in the right forum
    Aug 2009
    294
    Hey Jim.
    Are you clicking on "Trace Bitmap" from the Path menu? What you are moving out of the way is what you want to keep. It sounds like you might be leaving the Trace Bitmap step out, and you are deleting the photo. I hope I understood your problem...I use Inkscape to machine my logo and other text or graphics with my mill.
    Hey Mr. C,
    Yes I am using trace bitmap I am following the instructions frame by frame, where the video goes and gets an albert Einstein ,gif I am using a picture that I scanned on my scanner, when I place the picture in the inkscape and then slide to the left I have no pic in the box to delete
    Jul 2016
    660
    Can you post your picture here sir? Can I try it? I will post the G-codes here
    Quote Originally Posted by KH0UJ View Post
    Here is one of the pics please let me know what I am doing wrong in inkscape.
    Jul 2016
    660
    Ok im drawing it now, do you want this to be embossed? size of tool bit? and preferred size on the drawing?
    Jul 2016
    660
    Awaiting orders sir
    Jul 2016
    660
    Ballon SVG.zip
    Here`s the SVG file sir I was waiting for your desired measurements to make it directly to G-Code and post it here, but I was getting sleepy now
    Height is 10cm and width at widest point is 9-I/2 cm. This is dead flat as there are a total of four pieces that slot together to make a replica hot air balloon. What software do you use to convert to G-Code?
    Jul 2016
    660
    Quote Originally Posted by wisconsinjimmy View Post
    You forgot to mention what size of tool bit you want to use sir im using a bizarre software combo, im using google sketchup with a G-code plug-in, they are all free, it`s not automated though for I need the information of the tool bit to start with or else if you use a larger tool bit the cut will be smaller, or if it`s a smaller bit the cut will be bigger, so I need to compensate the tool bit used in the drawing itself so that if you use it on the actual machine it will cut precisely on your desired measurements.
    To be honest I have not given it a thought but you could use 1/8"
    Jul 2016
    660
    Here you go sir I just figured out you cannot really cut anything on zero Z, so I just set it to 0.3mm depth. you can modify the code if you want. copy and paste the code in a notepad and save.
    Code:
    ( T3 : 3.0 )G21 G90 G91.1 G64 G40
    G0 Z3.0
    ( T3 : 3.0 )
    T3 M6
    ( 1 )
    G17
    M3 S18000
    G0 X0.0485 Y-3.7593
    G0 Z1.0
    G1 F1600.0 Z-0.3
    G1 Z0.0
    ( 2 )
    S18000
    G0 Z3.0
    G0 X-3.7096 Y-3.841
    G0 Z1.0
    G1 Z-0.3
    G1 X-4.2031 Y-3.8602
    G1 X-4.3174 Y-3.8647
    G1 X-5.7868 Y-3.9219
    G1 X-9.122 Y-4.261
    G1 X-12.4296 Y-4.8075
    G1 X-15.6966 Y-5.5593
    G1 X-18.9104 Y-6.5134
    G1 X-22.0584 Y-7.6662
    G1 X-25.1284 Y-9.0131
    G1 X-28.1083 Y-10.549
    G1 X-30.9866 Y-12.2677
    G1 X-33.7521 Y-14.1627
    G1 X-34.9758 Y-15.1187
    G1 X-37.0632 Y-17.2269
    G1 X-38.96 Y-19.4621
    G1 X-40.6798 Y-21.8361
    G1 X-42.2125 Y-24.335
    G1 X-43.5492 Y-26.944
    G1 X-44.6818 Y-29.6479
    G1 X-45.6038 Y-32.4306
    G1 X-46.3098 Y-35.2759
    G1 X-46.7955 Y-38.1668
    G1 X-47.0581 Y-41.0865
    G1 X-47.0969 Y-44.0846
    G1 X-46.5967 Y-47.202
    G1 X-46.4261 Y-48.063
    G1 X-46.0014 Y-50.206
    G1 X-45.9026 Y-50.6241
    G1 X-45.2967 Y-53.1862
    G1 X-44.4836 Y-56.1387
    G1 X-43.5631 Y-59.0594
    G1 X-42.5364 Y-61.9446
    G1 X-41.4051 Y-64.7904
    G1 X-40.1704 Y-67.5928
    G1 X-38.8342 Y-70.3483
    G1 X-37.3982 Y-73.0532
    G1 X-35.8643 Y-75.7037
    G1 X-34.2602 Y-78.2555
    G1 X-32.2831 Y-81.6408
    G1 X-29.3787 Y-86.1577
    G1 X-26.2836 Y-90.546
    G1 X-23.0035 Y-94.7978
    G1 X-19.5443 Y-98.9053
    G1 X-15.5176 Y-103.291
    G1 X15.6146
    G1 X19.6413 Y-98.9053
    G1 X23.1005 Y-94.7978
    G1 X26.3806 Y-90.546
    G1 X29.4757 Y-86.1577
    G1 X32.3801 Y-81.6408
    G1 X34.3572 Y-78.2555
    G1 X35.9613 Y-75.7037
    G1 X37.4952 Y-73.0532
    G1 X38.9312 Y-70.3483
    G1 X40.2674 Y-67.5928
    G1 X41.5021 Y-64.7904
    G1 X42.6334 Y-61.9446
    G1 X43.6601 Y-59.0594
    G1 X44.5806 Y-56.1387
    G1 X45.3937 Y-53.1862
    G1 X45.9996 Y-50.6241
    G1 X46.0984 Y-50.206
    G1 X46.5231 Y-48.063
    G1 X46.6937 Y-47.202
    G1 X47.1939 Y-44.0846
    G1 X47.1551 Y-41.0865
    G1 X46.8925 Y-38.1668
    G1 X46.4068 Y-35.2759
    G1 X45.7008 Y-32.4306
    G1 X44.7788 Y-29.6479
    G1 X43.6462 Y-26.944
    G1 X42.3095 Y-24.335
    G1 X40.7768 Y-21.8361
    G1 X39.057 Y-19.4621
    G1 X37.1602 Y-17.2269
    G1 X35.0728 Y-15.1187
    G1 X33.8491 Y-14.1627
    G1 X31.0836 Y-12.2677
    G1 X28.2053 Y-10.549
    G1 X25.2254 Y-9.0131
    G1 X22.1554 Y-7.6662
    G1 X19.0074 Y-6.5134
    G1 X15.7937 Y-5.5593
    G1 X12.5266 Y-4.8075
    G1 X9.219 Y-4.261
    G1 X5.8838 Y-3.9219
    G1 X5.0667 Y-3.8901
    G1 X4.3001 Y-3.8602
    G1 X3.8123 Y-3.8412
    G1 X3.802 Y-3.5562
    G1 X3.7758 Y-3.2724
    G1 X3.7282 Y-2.9914
    G1 X3.6574 Y-2.7076
    G1 X3.57 Y-2.4442
    G1 X3.4602 Y-2.1812
    G1 X3.3308 Y-1.9272
    G1 X3.1826 Y-1.6838
    G1 X3.0164 Y-1.4523
    G1 X2.833 Y-1.2341
    G1 X2.6481 Y-1.0441
    G1 X2.4196 Y-0.8424
    G1 X2.1917 Y-0.6711
    G1 X1.9516 Y-0.5176
    G1 X1.7005 Y-0.3828
    G1 X1.44 Y-0.2673
    G1 X1.1714 Y-0.1719
    G1 X0.8964 Y-0.0971
    G1 X0.6165 Y-0.0434
    G1 X0.3333 Y-0.0111
    G1 X0.0485 Y-0.0003
    G1 X-0.2362 Y-0.0111
    G1 X-0.5194 Y-0.0434
    G1 X-0.7993 Y-0.0971
    G1 X-1.0743 Y-0.1719
    G1 X-1.3429 Y-0.2673
    G1 X-1.6035 Y-0.3827
    G1 X-1.8545 Y-0.5176
    G1 X-2.0947 Y-0.6711
    G1 X-2.3225 Y-0.8423
    G1 X-2.5367 Y-1.0303
    G1 X-2.736 Y-1.234
    G1 X-2.9193 Y-1.4523
    G1 X-3.0856 Y-1.6837
    G1 X-3.2338 Y-1.9272
    G1 X-3.3632 Y-2.1811
    G1 X-3.4729 Y-2.4441
    G1 X-3.5625 Y-2.7147
    G1 X-3.6312 Y-2.9913
    G1 X-3.6788 Y-3.2723
    G1 X-3.705 Y-3.5561
    G1 X-3.7096 Y-3.841
    G0 Z3.0
    G0 X-10.5487 Y-14.316
    G0 Z1.0
    G1 Z-0.3
    G1 X-10.7609 Y-14.6382
    G1 X-12.2805 Y-17.3066
    G1 X-13.6245 Y-20.0676
    G1 X-14.7871 Y-22.9097
    G1 X-15.7636 Y-25.821
    G1 X-16.5498 Y-28.7893
    G1 X-17.1425 Y-31.8023
    G1 X-17.5392 Y-34.8473
    G1 X-17.7383 Y-37.9116
    G1 X-17.7388 Y-40.9823
    G1 X-17.6377 Y-42.5478
    G1 X-17.5459 Y-45.3405
    G1 X-17.4072 Y-48.1635
    G1 X-17.2228 Y-50.9839
    G1 X-16.9928 Y-53.801
    G1 X-16.717 Y-56.6139
    G1 X-16.3957 Y-59.4221
    G1 X-16.0289 Y-62.2246
    G1 X-15.6168 Y-65.0208
    G1 X-15.1593 Y-67.81
    G1 X-14.6567 Y-70.5914
    G1 X-14.1102 Y-73.3584
    G1 X-13.7014 Y-75.3508
    G1 X-13.2963 Y-77.338
    G1 X-12.894 Y-79.3257
    G1 X-12.4943 Y-81.3139
    G1 X-12.0974 Y-83.3027
    G1 X-11.7031 Y-85.292
    G1 X-11.3115 Y-87.2819
    G1 X-10.9226 Y-89.2723
    G1 X-10.5364 Y-91.2632
    G1 X-10.3318 Y-92.3255
    G1 X-11.0931
    G1 X-11.646 Y-90.9391
    G1 X-12.7262 Y-88.1565
    G1 X-13.7811 Y-85.3641
    G1 X-14.8103 Y-82.5622
    G1 X-15.814 Y-79.751
    G1 X-16.792 Y-76.9307
    G1 X-17.7441 Y-74.1017
    G1 X-18.6704 Y-71.264
    G1 X-19.5708 Y-68.4181
    G1 X-20.4451 Y-65.564
    G1 X-21.2914 Y-62.7086
    G1 X-21.9372 Y-60.3654
    G1 X-22.5122 Y-58.0108
    G1 X-23.018 Y-55.6404
    G1 X-23.4539 Y-53.2562
    G1 X-23.8198 Y-50.8602
    G1 X-24.1151 Y-48.4545
    G1 X-24.3398 Y-46.0412
    G1 X-24.4935 Y-43.6223
    G1 X-24.5762 Y-41.2
    G1 X-24.5875 Y-38.8222
    G1 X-24.3182 Y-35.9308
    G1 X-23.7784 Y-33.0749
    G1 X-22.973 Y-30.2823
    G1 X-21.9092 Y-27.5775
    G1 X-20.5964 Y-24.9844
    G1 X-19.0462 Y-22.526
    G1 X-17.2721 Y-20.2237
    G1 X-15.2899 Y-18.0981
    G1 X-13.1171 Y-16.1678
    G1 X-10.7728 Y-14.4498
    G1 X-10.5487 Y-14.316
    G0 Z3.0
    G0 X-24.57 Y-16.7141
    G0 Z1.0
    G1 Z-0.3
    G1 X-26.9481 Y-18.9381
    G1 X-29.9447 Y-22.6225
    G1 X-32.4138 Y-26.6792
    G1 X-34.31 Y-31.0333
    G1 X-35.5982 Y-35.6043
    G1 X-36.2544 Y-40.3078
    G1 X-36.2668 Y-45.0569
    G1 X-35.9156 Y-47.673
    G1 X-34.9003 Y-51.8477
    G1 X-29.858 Y-65.9371
    G1 X-28.3809 Y-69.6159
    G1 X-26.8328 Y-73.2525
    G1 X-25.2098 Y-76.8563
    G1 X-23.5127 Y-80.4258
    G1 X-22.8776 Y-81.6935
    G1 X-23.0372 Y-81.4683
    G1 X-24.7784 Y-78.9257
    G1 X-26.479 Y-76.3557
    G1 X-28.1384 Y-73.759
    G1 X-29.7563 Y-71.1361
    G1 X-31.3321 Y-68.4879
    G1 X-32.8719 Y-65.8039
    G1 X-34.3022 Y-63.3261
    G1 X-35.5828 Y-60.7474
    G1 X-36.7224 Y-58.6128
    G1 X-37.6873 Y-56.4659
    G1 X-38.5043 Y-54.2584
    G1 X-39.1694 Y-52.0006
    G1 X-39.6797 Y-49.7028
    G1 X-40.0328 Y-47.3756
    G1 X-40.227 Y-45.0299
    G1 X-40.2615 Y-42.6764
    G1 X-40.136 Y-40.3259
    G1 X-39.8513 Y-37.9894
    G1 X-39.4085 Y-35.6777
    G1 X-38.8195 Y-33.4383
    G1 X-37.8031 Y-30.9049
    G1 X-36.5524 Y-28.4524
    G1 X-35.0861 Y-26.1224
    G1 X-33.4161 Y-23.9338
    G1 X-31.556 Y-21.9044
    G1 X-29.5209 Y-20.0505
    G1 X-27.3272 Y-18.3872
    G1 X-24.9927 Y-16.928
    G1 X-24.57 Y-16.7141
    G0 Z3.0
    G0 X10.7207 Y-14.3877
    G0 Z1.0
    G1 Z-0.3
    G1 X10.857 Y-14.4691
    G1 X13.1995 Y-16.1858
    G1 X15.3708 Y-18.1147
    G1 X17.3515 Y-20.2387
    G1 X19.1242 Y-22.5392
    G1 X20.6733 Y-24.9959
    G1 X21.9851 Y-27.587
    G1 X23.0481 Y-30.2897
    G1 X23.8528 Y-33.0803
    G1 X24.3923 Y-35.934
    G1 X24.6614 Y-38.8232
    G1 X24.65 Y-41.1995
    G1 X24.5674 Y-43.6212
    G1 X24.4137 Y-46.0394
    G1 X24.1891 Y-48.452
    G1 X23.8938 Y-50.8571
    G1 X23.5281 Y-53.2524
    G1 X23.0923 Y-55.6359
    G1 X22.5867 Y-58.0057
    G1 X22.0118 Y-60.3596
    G1 X21.3662 Y-62.7022
    G1 X20.52 Y-65.5573
    G1 X19.6457 Y-68.4112
    G1 X18.7454 Y-71.257
    G1 X17.8192 Y-74.0944
    G1 X16.8671 Y-76.9232
    G1 X15.8892 Y-79.7433
    G1 X14.8856 Y-82.5543
    G1 X13.8564 Y-85.356
    G1 X12.8016 Y-88.1482
    G1 X11.7214 Y-90.9307
    G1 X11.1652 Y-92.3255
    G1 X10.4524
    G1 X10.6561 Y-91.2676
    G1 X11.0423 Y-89.2767
    G1 X11.4312 Y-87.2863
    G1 X11.8228 Y-85.2965
    G1 X12.2171 Y-83.3072
    G1 X12.614 Y-81.3185
    G1 X13.0137 Y-79.3303
    G1 X13.416 Y-77.3426
    G1 X13.821 Y-75.3555
    G1 X14.2299 Y-73.363
    G1 X14.7765 Y-70.5957
    G1 X15.2791 Y-67.8139
    G1 X15.7367 Y-65.0244
    G1 X16.1489 Y-62.2278
    G1 X16.5157 Y-59.4249
    G1 X16.837 Y-56.6164
    G1 X17.1128 Y-53.8031
    G1 X17.3429 Y-50.9856
    G1 X17.5273 Y-48.1649
    G1 X17.666 Y-45.3414
    G1 X17.7578 Y-42.5489
    G1 X17.8589 Y-40.983
    G1 X17.8584 Y-37.9108
    G1 X17.6593 Y-34.8451
    G1 X17.2624 Y-31.7986
    G1 X16.6694 Y-28.7841
    G1 X15.8827 Y-25.8143
    G1 X14.9058 Y-22.9016
    G1 X13.7426 Y-20.0581
    G1 X12.398 Y-17.2958
    G1 X10.8777 Y-14.6261
    G1 X10.7207 Y-14.3877
    G0 Z3.0
    G0 X25.0533 Y-16.9926
    G0 Z1.0
    G1 Z-0.3
    G1 X25.1135 Y-17.0303
    G1 X27.3821 Y-18.4482
    G1 X29.5705 Y-20.1075
    G1 X31.6007 Y-21.9569
    G1 X33.4563 Y-23.9814
    G1 X35.1222 Y-26.1647
    G1 X36.585 Y-28.489
    G1 X37.8326 Y-30.9355
    G1 X38.846 Y-33.4616
    G1 X39.4332 Y-35.6941
    G1 X39.875 Y-38.0009
    G1 X40.1592 Y-40.3324
    G1 X40.2844 Y-42.6778
    G1 X40.25 Y-45.0263
    G1 X40.0562 Y-47.367
    G1 X39.7039 Y-49.6892
    G1 X39.1947 Y-51.9821
    G1 X38.5309 Y-54.2351
    G1 X37.7158 Y-56.4378
    G1 X36.7529 Y-58.5801
    G1 X35.6139 Y-60.7135
    G1 X34.3339 Y-63.2911
    G1 X32.9047 Y-65.767
    G1 X31.3652 Y-68.4505
    G1 X29.7899 Y-71.0978
    G1 X28.1727 Y-73.7196
    G1 X26.5139 Y-76.3153
    G1 X24.814 Y-78.8843
    G1 X23.5134 Y-80.7834
    G1 X23.6763 Y-80.4583
    G1 X25.3741 Y-76.8874
    G1 X26.9976 Y-73.2822
    G1 X28.5464 Y-69.6442
    G1 X30.0243 Y-65.9634
    G1 X35.0683 Y-51.869
    G1 X36.0854 Y-47.6867
    G1 X36.4378 Y-45.0617
    G1 X36.4255 Y-40.3026
    G1 X35.7678 Y-35.5891
    G1 X34.4769 Y-31.0083
    G1 X32.5767 Y-26.645
    G1 X30.1023 Y-22.5797
    G1 X27.0994 Y-18.8875
    G0 Z3.0
    G0 X0 Y0
    G0 Z0
    M5
    M30
  1. How do I convert JPEG drawing to IGS file for fusion 360?
    By RussMachine in forum Autodesk CAM
    Last Post: 05-21-2016, 09:27 AM
  2. Need to convert a JPEG to DXF file
    By cutting edge in forum MetalWork Discussion
    Last Post: 08-27-2008, 02:05 PM
  3. convert DXF file to BMP, JPEG, etc.
    By 40fordcoupe in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 04-15-2008, 02:07 PM
  4. jpeg convert to dxf...can I do this?
    By mredican in forum Autodesk
    Last Post: 05-05-2005, 05:32 PM
