585,996 active members*
4,722 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Centroid Acorn now available and is the real deal.
Page 1 of 2 12
Results 1 to 20 of 28
    Apr 2003
    354
    Hello all, here's a link to Marty Escarcega's thread over in the Ajax/Centroid forum describing the switch from a Mach3 parallel port system to the newly released Centroid Acorn kit. I have one coming next week for my new mill and am SO excited. If you're used to dealing with Mach's issues, this will be a welcome relief for a very reasonable price. Imagine that, control software and hardware from the same American company....who'd a thunk it would ever happen for the hobby market!
    http://www.cnczone.com/forums/ajaxcn...42320-cnc.html
    Link to the product, check it out:
    Centroid Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication
    Milton in Tennessee ya'll!
    15362
    Re: Centroid Acorn now available and is the real deal.
    Quote Originally Posted by DICKEYBIRD View Post
    Looks like another interesting package to try, Centroid have always had a good control software
    Mactec54
    Jan 2006
    38
    This looks awesome. I personally think Tormach dropped the ball on the Path pilot system. Tried to buy just the conversion hardware and was told machine owners only. Centroid has been around awhile so this should be solid.
    Nov 2009
    4415
    Quote Originally Posted by thumper650 View Post
    Not true at all. Path Pilot is sold separately. However there is no support for home brews. I have it. Like everything else it needs a specific computer that will run Linux well and a Mesa card. Seems like the same issues with Mach and an SS or equivalent.
    A lazy man does it twice.
    Apr 2003
    354
    To me, the Acorn is like LinuxCNC/PathPilot for non-Linux proficient users (such as myself). The price isn't that far from what a Mesa & its peripheral items cost and the software is known to be solid. No compatability or setup issues either. The only unexpected issue I've had is that the CNC12 software requires a Win10 PC with a single thread benchmark of 1500. A trivial & relatively low performance number to you computer lovers but I did have to get something to replace my Mach3/XP/PP machine.
    Maybe Acorn's not for everybody but a it's miracle for me!
    I'm surprised more people aren't running their controllers on virtual machines. Windows, Linux, both easily and cheaply setup via free virtual machine software. It also vastly streamlines the software operation while letting you run a full OS in the background. I use Mach3 and have an ESS, but if I go the Linux path at some point, which I'm 100% sure I will, I'll just run the proper install on a VM. In fact I've already played around with Linux CNC doing just that. I'd need LCNC compatible hardware to make things move, but that's all id need. My PC can operate as is basically. With modern PC hardware there is no need to slimmed and optimized installs, especially when the parallel port started phase out in the late 90's. That people still use them speaks more for the need for cheap hardware than it does to some sort of desired performance. All of that said, I'll likely venture down the Acorn route eventually as well. I like good software and so I try to experiment when time and money allows.
    Jan 2008
    1529
    Virtual machines introduce additional delays and timing issues.
    Dual boot is a different issue.
    Quote Originally Posted by pippin88 View Post
    You are absolutely right. However, that effective latency is basically unnoticeable assuming decent hardware and proper VM optimization, and in some cases VM's have better drivers than can be found for standalone installs. Often, latency issues that people see, especially for Linux machines, are caused by drivers. RAM is also a big deal, and most don't spend the time understanding or relocating memory as necessary. I ran Mach 3 on my MacBook inside Parallels desktop using an ESS for quite a while. After a bit I got tired of coolant and grease and other garage regularities messing up the MacBook that I use for business management and personal activities. As a result I built a PC. Asides from the PC running windows 7 x64, there is no noticeable difference in performance. I also ran Siemens NX, Solidworks, ArcGIS, and many other fairly heavy pieces of software inside the VM on my MacBook without any real issues. I do enjoy having a 22" monitor now instead of the laptop screen, and it's nice that the PC has pretty good GPU performance (comparatively to the Mac) so running CAD/CAM, surfing the web, making tooling or setup notes, all while Mach is machining parts is no issue whatsoever. Cost for the PC was around $600 (built myself) plus a monitor. I had the GPU, it's several years old. Looking at tooling costs, fixture costs, machine costs, the PC is a drop in the bucket. As it's been so reliable, it's one less thing to worry about so that I can focus on the important stuff. Mach 3 has seen 4 days of uptime (not a single restart of the PC or closure of Mach 3) as of this morning without a single issue, the can't be said for the operator or the programming (also done by me). I try to install OS updates on Friday evenings, but do so manually, no auto-updates.
    Obviously, a VM setup is for the more technically advanced, but it's a vastly more flexible setup and suffers very few drawbacks should you be able to do it. Generally I run no less than four cores and 16gb of ram. My MacBook (late 2012) meets that and my Mach 3 PC has 24gb of ram and 3gb of dedicated GPU memory. I also use SSD main drives for both. Large data gets offloaded onto a separate internal drive either via SSD or HDD, even when the second disk is a HDD data transfer is extremely fast when the disk is not being written to as you are trying to read like is common with single disk HDD setups. The problems of old simply aren't a reality today. Linux and OSX both are very ram and processor friendly, hell the new Macs run on mobile processors basically. So when you have more robust processing and RAM to spare a VM runs in many cases like a native install and sometimes even better.
    Apr 2015
    7
    Almost pulled the trigger on Acorn, but went with UCCNC because Acorn does not have MODBUS communication, I need that for nearly infinite flexibility in talking to accessories/gizmos. Modubus is huge when building/adding on to specialized machines.
    Apr 2018
    A dedicated computer with a single OS is better, of course, and considering the low requirements it seems most people should be able to find a free computer or something used extremely cheap.
    Problem with using any computer to control a CNC machine is that the computer is also doing other things, like accessing the hard drive for example, or switching the importance of one program over another, or expanding the page file, whatever it might be. This is the reason Windows causes so many problems with setups that do not have a dedicated processor like the Acorn does.
    The advantage of the Acorn in this example is that it does all the work, and is solely dedicated to doing that work and absolutely nothing else. No interruptions, no other demands on the processor it's singularly focused on directing your mill. Anything that controls your CNC machine, from a Windows based platform, regardless of how good the software is, would be my absolute last choice for driving a CNC machine. Now using a Windows based computer to send information to an Acorn controller is a totally different story.
    Duel boot would probably be next to last, single boot would be better, and single boot with a processor like an Acorn would be my top choice, hands down. It's a great solution for people who want detail with no miss-stepping in my humble opinion.
    Jun 2015
    943
    Quote Originally Posted by Scott_Noble View Post
    All Windows based motion controllers work like how you described. Mach3/ESS. UCCNC/UC400ETH, PlanetCNC/MKx etc., it is really a good solution for Windows non-realtime problems.
    The other solution is to use a realtime kernel OS like how Linuxcnc does.
    Sep 2009
    1856
    get a real time windows based machine then
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Feb 2018
    92
    I haven't looked closely at the communications with the acorn board, but I believe it interprets the g-code onboard so all this discussion about latency is a moot point. Maybe I'm wrong.
    Mar 2007
    304
    I am thinking about putting an Acorn on my next Dyna Myte 2400 lathe conversion. But I am not sure how to set up the Automatic Tool Changer/Rotary Turret for the different tools. Support seems to be from the user base mainly. That concerns me.
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Apr 2003
    354
    Quote Originally Posted by CNC-Joe View Post
    The next release of Acorn CNC12 software is supposed to include ATC setup as part of the "Wizard." I have no idea how it well it will work across all the different ATC types but since Dyna is pretty popular, it should work well. Me? I don't do long production runs & just use a standard QCTP & holders.
    The support from users is getting better & better now that more & more experienced users are switching from other systems and getting on board with the Acorn. The Centroid staff is great too! Don't think that there's no help from them...couldn't be farther from reality. Like my pappy used to say: "Son, ya' pays yer money & takes your choice!":cheers:
    Feb 2018
    92
    Before I made my decision to buy the acorn, it became pretty clear to me that many of the other choices on the market were doing amateur night. This one here was well sorted right out of the box. I plugged it in, wired it and it worked.
    Mar 2007
    304
    Thanks for the information, Milton. I'd love to be a beta tester for that software and get that second DynaMyte DM3000 running. (Ok there is always the thought of making a bar feeder for the lathe, too). One step at a time.
    www.CNC-Joe.com
    Nov 2009
    4415
    That will be a 1st. A 2400 lathe with a tool changer? ;-)
    Sent from my iPhone using Tapatalk Pro
    Mar 2007
    304
    Quote Originally Posted by Fastest1 View Post
    Sorry- I mis-spoke -it is a DM3000 lathe not the D2400 mill.
    www.CNC-Joe.com
    May 2005
    3920
    That seems to be part of the deal, this hardware is being marketed as a DIY solution. Centorid still offers full support solutions so you do have options with them. In fact I can't think of too many companies that are now offering such a wide array of solutions, from hobby, to DIY, to fully supported. It is a very interesting move on their part and it will be interesting to see what the market looks like in 5 years.
    That concerns me.
    I think their goal is to offer up this hardware and software solution, like a lot of publicly supported solutions where the majority of the support is via user groups. Sort of similar to Linuxcnc, Machine Kit, GRBL and others.
Page 1 of 2 12
  1. Acorn on a Dyna Myte DM2400
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 08-10-2017, 09:36 PM
  2. Acorn on a D&M4 Benchtop CNC Mill
    Last Post: 08-09-2017, 02:26 PM
  3. Those interested in ACORN
    Last Post: 08-09-2017, 02:23 PM
  4. Acorn Thread Dies
    By chelclock in forum Want To Buy...Need help!
    Last Post: 07-26-2010, 05:49 PM
  5. A Real Ball Screw Deal
    By smarbaga in forum Linear and Rotary Motion
    Last Post: 07-07-2005, 08:57 PM
