585,749 active members*
3,839 visitors online*
Results 1 to 8 of 8
    Dec 2014
    46
    Mach3 PWM Error
    I need help,
    I have a Huanyang VFD,
    Trying to get Mach 3 to control the spindle
    I have tried every port / pin configuration I can think of.
    I either get "PWM bumped error"
    Or E Stop selected
    Any help is appreciated
    Re: Mach3 PWM Error
    This means that youre g-code is commanding an rpm lower than the minimum pwm % that you have set.
    If you want help, you need to be more specific about what the problem is.
    Try the ones you actually used. You assign one pin to the spindle step pin, and one for your M3 relay. You should know which pins you are using.
    Try explaining exactly what is happening, one step at a time.
    Dec 2014
    46
    Re: Mach3 PWM Error
    Thanks for the reply,
    I will try to provide more details
    1. When I press the Spindle SW in Mach3 it turns yellow then E Stop kicks in,
    I have attached pictures of my Ports & Pins, SS Config, If you need more detail let me know.
    I appreciate your help
    Re: Mach3 PWM Error
    Noise from your VFD is triggering your estop input. Try adding some noise filtering for the estop input.
    Dec 2014
    46
    Re: Mach3 PWM Error
    Can you tell me how to add the filtering ?
    Does the configuration look out to you?
    Re: Mach3 PWM Error
    On the Motor Outputs page,set the dir port and pin to 0, not 8 and 9.
    You have Output # 2 assigned to M4, M7, and M8 (CCW, mist, and flood) Are you using any of them? It should only be assigned to one of them, if you are using one of them??
    I've never used a smoothstepper, but it looks like you just add a value in the box next to the estop in the Noise Filtering section.
    Re: Mach3 PWM Error
    What kind of spindle do you have? PWM minimum should be less than 100%, or you won't be able top control the speed. If you have a 24,000 rpm spindle, and your minimum speed is 8000, then PWM min % should be 33%.
    Dec 2014
    46
    Re: Mach3 PWM Error
    Thanks for the help,
    Still trying to it working. I am using a Bridgeport style Knee mill.
    60Hz motor, The VFD controls the motor well manually just need Mah3 to control the VFD,
    All help is appreciated
  1. Mach3 error
    By Olavi in forum Mach Software (ArtSoft software)
    Last Post: 06-15-2013, 01:20 AM
  2. MACH3 error help
    By Hellbourne in forum Australia, New Zealand Club House
    Last Post: 04-11-2013, 08:30 AM
  3. mach3 error
    By Kevin44 in forum Mach Software (ArtSoft software)
    Last Post: 08-09-2012, 04:50 PM
  4. error mach3
    By Diegone in forum Spanish
    Last Post: 07-08-2012, 08:56 PM
  5. Mach3 & VCarvePro error
    By mdclockguy in forum Machines running Mach Software
    Last Post: 12-21-2009, 11:49 PM
