Please excuse my limited electronics knowledge in advance
I am trying to wire 6 SN04-N NPN NO 10-30v proximity sensors to this KL-1212 breakout board ( https://www.automationtechnologiesin...face-breakout/ ) to serve as home/limits on a cnc router I am building. There are a few threads about wiring 12v sensors and 5v boards but I am still not quite 100% confident and do not want to fry anything.
After doing a lot of reading on this AFTER I purchased them I have come to realize that I probably should have got NC sensors for fail safe operation and that proximity sensors do not necessarily simply hook up straight to the inputs depending on various voltages etc, but at this point they are installed and all the cables routed in my machine so I figure I will see If I can get them working. I have up until now used mechanical limit switches on other builds which are pretty simple.
The KL-1212 board I am using does not appear to have a full manual, just basic pinout and wiring diagrams so I am not 100% certain about the specs of the inputs but they measure 5v when the board is on.
The second problem is that I am not 100% certain if the sensors have internal pull-up resistors or not from the specs, but they do measure 10k between the +v and signal (brown and black) wires so I assume that means they have an internal 10k pullup resistor..? Is this correct?
Anyway, I have wired up more or less like the diagram attached that was supplied with the board except that I was going to split the 6 limits into 3 pairs, with the pairs each wired in parallel, then each of the 3 pairs then wired to separate inputs on the board for x, y, z and operate them as shared home and +/- limits for 3 axis in Mach 3. The drawing shows 3 limits all wired to one input.
I have not connected the sensor outputs to the board at this point as I am not sure if I need to use resistors or perhaps relays to avoid frying anything. If I understand what I am reading correctly I should not simply hook the output wires from the sensor to the input on the board due to the 12v sensor and the 5v board and the fact that the sensors appear to have 10k pullup resistors internally? correct?
The board is powered with a 24v switching supply and there are 5v and 12v taps. The inputs measure 5v when the board is on. I am using the 12 v tap for the proximity sensors
Would one of you kind souls help walk me through wiring them up so I do not blow up my board?
If I do need resistors can you help with values and how I would wire everything up with the 3 pairs of sensors to 3 inputs layout I want to try (assuming that seems to be a logical way to hook them up that is, other suggestions would be considered)
thanks in advance!
