4x8 CNC Router with four spindles changing automatically
4x8 CNC router for sale with reasonable price, Multi-spindles automatically changing, humanization design, top quality accessories, high-performance drive motor and imported high-precision ball screw.
Advantages of 4x8 CNC wood router with Multi-spindles:
1. The Multi-spindles CNC router bed structure using generous walled tube T-type structure,tempering and vibration aging treatment with import 5 axis metal milling precision Machining centers.
2. The whole structure with side mount rails, with high performance and precision, dust-proof design of the whole structure of the rack rails with sub-type structure, rail replacement without professionals,more convenient.
3. Multi-spindles can automatic change to save time and only set origin one time, avoid tool marks.
4. Perfect design, top quality accessories, to minimize the Machine’s failure rate.
5. High-performance drive motor to ensure the machine’s high speed and accuracy.
6. Imported high-precision ball screw, which moving smoothly, to ensure the machine’s high precision.
7. Two motors for Y-axis, high speed.
8. Breakpoint specific memory to keep the carving status when power off, processing time forecast and other functions in case of the accidental power outages.
9. The body of CNC router machine is strong, high-precision, reliable and durable.
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
