585,880 active members*
3,930 visitors online*
Results 1 to 2 of 2
    May 2016
    NLX 2000 Work Counter Issue
    For the life of me, I can't figure out why my program continues to loop once it has met the total number of pieces (12) that I set. I'm sure it's probably something simple that I'm overlooking, and I hope someone on here can help me out.
    The end of my program says the following:
    G330(B-AXIS HOME)
    M36(SPINDLE SYNC OFF)
    G18G53X-5.Y0.Z-10.
    M5
    M89
    M1
    /M99
    M30
    I can get 12 pieces per bar, and I have that set in the work counter screen (see attached images). I've read both programming manual and operational manuals trying to figure out why it keeps running after reaching the 12 piece limit I had set. The books make reference to having 2 options to choose from 1) Start Interlock or 2) Block Delete Function. Nowhere in the manuals does it say how to or where to choose either option, and its not listed on the Work Counter screen as you can see in the the attached images. Can anyone help explain or point me in the direction to choose an option? Thanks in advance!
    May 2016
    Welp, I found it. It's located in Setting / Operation Panel. Then I changed Work Counter from Start Lock to Block Delete
  1. Work Ejector Doosan Puma MX 2000 ST
    By fmlfred in forum Daewoo/Doosan
    Last Post: 07-17-2017, 03:44 PM
  2. Auto CAD 2000 Crash issue
    By ozgedney49 in forum Autodesk
    Last Post: 08-06-2015, 06:53 PM
  3. Work Transfer Doosan - Puma TT 2000 SY
    By The-Chip in forum Daewoo/Doosan
    Last Post: 10-17-2014, 07:27 PM
  4. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  5. Divided by 4 Counter for 2000 pulse encoder
    By ahmedrehan in forum UHU Servo Controllers
    Last Post: 03-28-2009, 09:10 PM
