585,974 active members*
4,229 visitors online*
    Aug 2017
    13
    Help with Mach3
    Just trying Mach3 for first time in demo, i generated some g-code for a PCB that i designed in Eagle..the G-code ran fine found that the board image is small and tried to zoom the image on the image screen but it starts to disappear off the top of the window ..how can i zoom without it rotating as a 3D image so i can see the operation as i run
    Regards John
    Re: Help with Mach3
    Zoom with the mouse wheel. Pan by holding the right mouse button and dragging.
    Aug 2017
    13
    Re: Help with Mach3
    Thanks for that never thought of Right mouse has usually its a left mouse to move.
    One further point I am having difficulty finding on You Tube or any other forums, I want to use a Web Cam on occasions instead of a generated G - Code using Eagle, I want to be able to use a Webcam mounted in the Spindle motor position to manually program hole positions for a Printed circuit board using a Negative / Positive photo of the board placed on the CNC table with pre-designated tooling maks i.e a cross hair on the photo to mark as start position of the piece I want to drill or rout, I know I can get a cross hair for Mach3 and use the Jog to move the XY position manually BUT I cannot find any help with the actual creation of the co-ordinates that i want to program, can anyone help in this operation.
    Regards John
    Re: Help with Mach3
    Aug 2017
    13
    Re: Help with Mach3
    Thanks for info, I downloaded the Zip file and doesnt look like an EXE file so was wondering how I use, also found under Wizards in Mach3 what looks like the same Copycat wizard but when I tried to run it displayed I had no license for Copycat wizard but no link to get license.
    Looks like it might work for me.
    Also downloaded a copy of Artcam so will try that as well.
    Regards John
  1. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  2. To mach3 or not mach3, opinions requested
    By KenCameron in forum HURCO
    Last Post: 10-07-2014, 10:05 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  4. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
  5. I cant get Mach3 to run
    By Crawler374 in forum Mach Software (ArtSoft software)
    Last Post: 09-07-2009, 06:11 PM
