586,000 active members*
4,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > PathPilot on Novakon Torus Pro
Page 2 of 4 1234
Results 21 to 40 of 77
  1. #21
    Jun 2004
    6618
    Re: PathPilot on Novakon Torus Pro
    Right.
    I have learned to just be satisfied with the version I have installed on both the lathe and the Pulsar.
    As long as it is all working fine, there is less risk this way.
    That said, if these were hobby machines, I would be running the latest update on both. Why not.
    Lee
  2. #22
    Mar 2009
    388
    A couple things I've bought since installing PathPilot that have become indespensible:
    1) Tool Setter https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Recommended by Mr. Bonedoc. This thing is great for quickly setting the tool heights of your tools to place in your tool table. Not sure how I lived without this thing in the past! I was using a granite block, and height gauge, but this thing is a lot faster!
    2) Shuttle - https://www.tormach.com/store/index....show&ref=30616 I was using one of the E-Bay jog shuttles with Mach3, but this shuttle has much better control of speed when you are sneaking up on a part. This is just a re-labeled shuttle from another manufacturer, but its not that much more expensive directly from tormach.
    3) USB WiFi network controller - https://www.tormach.com/store/index....show&ref=38207 I tried a few other WiFi controllers that I had laying around but none of them worked with Linux. So, I bought this one, cheap and problem solved.
    Scott...
    Instructional Videos for CNC Guitar Building
    http://www.rmgvideos.com
  3. #23
    Aug 2007
    701
    Quote Originally Posted by sagreen View Post
    Scott...
    Umm, that's Dr. Bonedoc.....
  4. #24
    Jun 2004
    6618
    Word Doc.
    Lee
  5. #25
    Feb 2006
    7063
    Now that you've gotten a taste of what it's like to have a pendant, do yourself a really BIG favor and buy a GOOD one, like one of the VistaCNC pendants with a real MPG. A real MPG is light-years better than the crappy Shuttle. It'll be the best money you'll ever spend on your machine. Well, other than the PDB, of course! :-)
    Regards,
    Ray L.
  6. #26
    Aug 2007
    701
    Ray is the vista plug n play w pathpilot?
  7. #27
    Feb 2006
    7063
    Quote Originally Posted by brianbonedoc View Post
    They do have models that support LinuxCNC so they should work with PP. E-mail Lee at VistaCNC ([email protected]), to confirm details. If it makes sense to add/change something specific to better support PathPilot, I would not be surprised if he was open to adding a PP variant.
    Regards,
    Ray L.
  8. #28
    Apr 2005
    1268
    Hey Guys;
    I've attempted to install pathpilot (latest) on my pro servo but no joy!
    I purchased the dvd and new solid state drive for the installation. I actually installed pathpilot on the new drive using a separate computer and all went well. I then installed the mesa card, new hard drive and plugged in all cables on my machine. I get the Tormach splash screen and it starts blinking and will not let me exit to the terminal. It finally exits itself and I get the following message;
    ALERT /dev/disk/by-uuid/784079a0-da5e-49d3-8729-c0dcd7b15e3dropping to a shell.
    My motherboard is the gigabyte ga-h61m-52pv and I have installed the new design bob from John.
    Fortunately I did not screw up the original drive so I returned everything back to the original configuration and am back in business.
    BUT...........Any idesa????
    I know nothing about linux so I'm completely lost!
    Any help will be appreciated.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  9. #29
    Aug 2007
    701
    Bill - try installing it on the actual Torus computer. I had issues like that too. Eventually i changes motherboards and all was fine. You may have to mess w/ bios settings too.
    My guess is if you install it on the actual controller it will work.
  10. #30
    Apr 2005
    1268
    Hey Brian;
    I already tried that and same results. The novakon computer appeared to read the install disk but still did not install correctly. I worried about the bios also but if the mb is not communicating with the hard drive, I don't think I would get the tormach splash screen so communication appears to be there with the new hard drive. Also, I tried another hard drive (not a ssd) and same results Wish I knew more about linux. I'm afraid that I nave a motherboard that my not be compatible. Has anyone else been successful with the gigabyte ga-h61m-52pv(stock novakon) motherboard?
    Scott;
    I don't want to hijack this thread but I thought having issues like this one discussed here would be beneficial to future trouble shooting for others.
    Let me know if it is a problem and I'll start a new thread.
    Thanks guys for all the help..
    Bill
    billyjack
  11. #31
    Aug 2007
    701
    Bill - yeah just cut to the chase and change mobos- I had that same issue.
  12. #32
    Jun 2004
    6618
    The only trouble I had with the onboard MOBO was I ordered the wrong Mesa card. Once I got the correct board for the PCI express, it worked fine. For awhile. I just ordered a refurbed computer to replace everything and ordered all longer cables and I am back in business.
    The computer now sits on top of a shelf instead of inside the control panel. Turns out that the main issue was a video extension cable that I was using and not the Novakon MOBO or the Mesa Card. So, I have some spares now.
    Lee
  13. #33
    Jul 2006
    45
    Quote Originally Posted by bill south View Post
    Hey Brian;
    Scott;
    Bill
    FWIW........ We did our install on the gigabyte GA-H81M-S2PV mobo that came with our Torus Pro, we had to change the bios settings to allow hot swapping of sata drives, and the boot order to read the disc drive first for the initial install...If I am remembering correctly we did this before we tried anything, so I have no idea what would have happened if we didn't...
    Ray
  14. #34
    Jun 2004
    6618
    I do remember getting into the Bios, but that was after the install of Path Pilot.
    It seems that the USB would not turn on fast enough to allow me to get into Linux. I wound up having to use a PS2 keyboard.
    Lee
  15. #35
    Jun 2014
    1780
    The only way I can reliably get into Linux is with ctrl + alt + x, works everytime for me.
    mike sr
  16. #36
    Jun 2004
    6618
    I didn't know about that then. That is a much more elegant solution and trying to catch the splash screen.
    Lee
  17. #37
    Apr 2005
    1268
    OK Guys;
    Just for the record, this is what I tried this weekend.
    1. Changed Monitors. The one I was using was an old touch screen so I thought maybe some sort of interference. No Joy!
    2. Changed Cables - I was using an extension cable to move the monitor to the front of machine. I moved everything to the rear of the machine and plugged directly into the motherboard. No Joy!
    3. Changed Keyboards - I was using a Logitech with a built in mouse pad. I switched to a PS2 style keyboard and regular mouse - No Joy!
    4. Reloaded software using original Path Pilot disk - Load appeared to work normally until reboot. Then the splash screen came up, timed our and back to the error I listed above. - No Joy!
    5. Reflashed the Bios. Went to Gigabyte website and verified the bios version for my board GA-H61-S2pv was current (version FB). I downloaded a newer version of the bios listed as pending and reflashed. - No Joy!
    The only thing left is to replace the motherboard. I'm going to order a GA-H81M-S2PV as listed above if it supports a 1155 socket and give it a try.
    If anyone has suggestions as to which motherboard may be supported and less expensive, please let me know.
    I must say that this has been really frustrating and expensive. I sure hope it is worth the effort!
    Bill
    billyjack
  18. #38
    Aug 2007
    701
    Bill - sounds like the frustration I went thru. Somewhere in tormach forums there’s a list of approved motherboards for PP. before u buy make sure it’s on that list. Trust me the headache will be worth it once u are up and running!!
  19. #39
    Jun 2004
    6618
    Bill, You might want to check out that refurb link I posted. That is a complete stand-alone system including shipping for $129.00.
    Hard to beat that price.
    It does work with Path Pilot.
    Then you can install it as a stand-alone system and switch back to Mach 3 anytime you want. That makes for an excellent backup system if you ask me.
    Lee
  20. #40
    Jan 2016
    386
    I am running PathPilot on an old ASROCK 775i65G motherboard with 1.5gb ram installed and running for over a year in my Pulsar without any issues. I also tried it in simulation on the ASUS H81M-D with 2gb ram without any problems. I am pretty sure I also installed it on an ASUS H81M-E as well.
    Steve
Page 2 of 4 1234
  1. PathPilot on Novakon
    By brianbonedoc in forum Novakon
    Last Post: 12-23-2017, 09:25 AM
  2. Replies: 38
    Last Post: 08-14-2017, 08:59 PM
  3. Another new Novakon torus pro
    By MBViklund in forum Novakon
    Last Post: 06-09-2015, 02:50 PM
  4. My new Novakon Torus Pro Lathe :-)
    By AUSTINMACHINING in forum Novakon
    Last Post: 11-24-2014, 09:44 AM
  5. PC to control Novakon Torus?
    By mud99 in forum Novakon
    Last Post: 06-01-2012, 10:54 AM
