585,959 active members*
4,516 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > want to change spindle mount
Results 1 to 6 of 6
    Jun 2017
    7
    ive got a 3040t or what ever they are called and id like to uprate the spindle so i brought a 600w thinking it would be a easy swop little did i relise the 600w spindle id 57mm wide
    so my problem now comes with mounting it to the z axis
    could any one please point me in the right direction to change the mount as mine is a one peice onto the axis picture included
    thanks
    Jun 2005
    1730
    Re: want to change spindle mount
    If that existing mount is say 80mm and the new spindle is 57mm, you might be able to make a sleeve to slide over the spindle, which would then go into the existing mount.
    Russ
    I think his mount is smaller.
    Jun 2017
    7
    yes the mount is 52mm
    Jun 2005
    1730
    In that case you only have a few options. You could cut the existing mount all the way across at the first outer fin closest to the bearings in the back. Then take a flat piece of 1/4" aluminum and bolt that to what is left of the old mount. Then drill holes in the 1/4" aluminum plate for the new mount that supports the new spindle. The other option is to design and build and entirely new mount assembly including the bears.
    Russ
    Jun 2017
    7
    just a bit of a update on this
    tried to take the mount of but it apears its put togeather in such a way with intefernce fit parts etc its a pain so fabrication seems like a no go, so ive took the easy option and order the 52mm sindle but a 400w. thanks for the help
  1. Replies: 6
    Last Post: 05-10-2016, 12:30 AM
  2. .8kw Spindle and VFD w/ Mount
    By techsavvy34 in forum For Sale Only
    Last Post: 09-22-2015, 07:31 PM
  3. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  4. CNC Plasma / CNC Router Quick Change Mount
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-18-2012, 06:06 PM
  5. Quick Change router/plasma torch mount
    Last Post: 05-25-2012, 06:46 PM
