586,000 active members*
5,031 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Building a custom PC case
    Aug 2017
    6
    So I'm in the early stages of designing and building my own computer case, and am unsure as to how I am going to build it (using a router or a CNC, which material is ideal, etc). At this point, I believe only a CNC is going to be capable of making the cuts required for this project. The material I've chosen is MDF, but I'm not sure it's strong enough at this size. To anyone with experience with remotely similar projects, I would greatly appreciate advice! I'm open to tweaking the design as well, just know that there are some size constraints, so there isn't a lot of wiggle room.
    Currently I've designed this with 1/2" sides that will allow for 'routing' using a table saw, and the cuts for the back, bottom, and two front pieces would probably need a CNC. I just don't know of any other method that could be used for such fine cuts (except maybe a surgeon wielding a dremel, lol)
    Jul 2016
    660
    Re: Building a custom PC case
    On a CNC you can do what ever you want I guess im also addicted to it few years back, from upward airflow all the way up to a refrigerated PC case
    https://www.techpowerup.com/gallery/2889/case-build-upward-airflow
    https://www.techpowerup.com/gallery/...rated-pc-final
    A whole table...
    That`s all the way down to a USB and a DVI slot machining
    Aug 2017
    6
    Nice work! Can you recall how much it cost to have the CNC work done, if I may ask?
    Jul 2016
    660
    That I dont know sir, for those years I did not use a CNC to make my PC projects, just bare hands and some power tools, but now im currently working on a manufacturing shop with CNC`s, it depends on how many minutes I guess (CAM programming to machine cutting), here in our place it`s per project, and usually customers get a bigger discount they order 3 or more last time I woked with an aluminum PC case my boss charged half the material cost.
  1. fitting a drone quadcopter to a custom case
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 04-12-2015, 06:05 AM
  2. fitting a custom case for the dreadnaught D28 guitar
    Last Post: 12-04-2014, 10:48 PM
  3. Building a case (Do I need ventilation)?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2012, 12:48 PM
  4. What plastic for custom laptop case?
    By VoKuS in forum Glass, Plastic and Stone
    Last Post: 03-26-2011, 02:51 PM
  5. My New Custom System I am building.
    By WallCrawler in forum Computers / Desktops / Networking
    Last Post: 12-09-2004, 02:31 AM
