585,761 active members*
4,045 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > can't import/open .pdf file
Results 1 to 6 of 6
    Sep 2014
    66
    Hi.
    I get the attached message when I try to open a pdf file. Others open OK but every now & then I run into this problem.
    Why dies this happen, and how do I correct or work around it?
    Rob.
    Apr 2004
    5735
    Re: can't import/open .pdf file
    What were you expecting to do with the PDF file in Rhino? Rhino is a 3D program; PDF is a 2D format. At best, you could bring it in as a background bitmap and trace over it. If Rhino won't accept it as a bitmap, convert it into JPG or BMP format and try again.
    Andrew Werby
    Website
    May 2006
    803
    There are "pdf to dxf converters" online.
    Search the phrase
    Sep 2014
    66
    Well...I was planning to model something loosely based on a plan...
    Thanks for the tip re the converter!!
    Rob.
    Jan 2016
    18
    A pdf can contain both vector and raster formats. Most likely the pdf you are trying to import is a raster format (pixel image). Rhino is looking for vector that it can use. Your only option would be to use it as a background and trace it in Rhino. By the way Rhino is not just a "3d program" it is very good at 2d.
    Jul 2018
    As far as shane-w mentioned above, the very pdf you're trying to import is likely to be a raster format one. Yet, laongside with the solution he suggested, you could as well edit the pdf formatting manually. If so, all you need is some pdf editing tool you have. I, as an example, use this one https://w9.pdffiller.com just because it's similar to Adobe Acrobat yet cheaper and works as web-based app, which is convenient for purposes of opening a file, editing just one thing and all along
  1. File import ?
    By glovebox20 in forum OneCNC
    Last Post: 03-13-2012, 01:13 AM
  2. Can't open/import an Inventor STL file
    By ingear in forum CamBam
    Last Post: 12-19-2010, 09:43 PM
  3. import .SAT file
    By Tinmuk in forum Surfcam
    Last Post: 07-23-2007, 10:28 PM
  4. file import(again)
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2005, 01:57 PM
  5. file import
    Last Post: 06-07-2005, 08:01 AM
