585,758 active members*
4,537 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Problem with A axis rotation
    Feb 2016
    28
    i bought used CNC router with XZA axis. I am trying to make program with Vectric 8.5 for it but when i save .nc program i got A axis rotates in same position many times till A360 and then after X Z movement it rotates back till 0 it takes about 1min in each A axis position to rotate and it rotates about 50 times. When i bought cnc router i got some programs with it and there bigest A axis coordinate is A6.7.. when i change A coordinates manually in vectric programs it works good but it takes time every time to change it manually. Could somebody help me to solve this problem? How to make vectric generate correct program?
    Re: Problem with A axis rotation
    Looks like they used a different post processor. What's the beginning of each file look like?
    Feb 2016
    28
    i dont realy know if it was made with vectric or other CAM software before. But now i am trying to make it with vectric. i tryed to change post processor, i tryed different cam softwares but every time i get A axis coordinate about 360
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Anayak problem with head rotation
    By rugbymatt in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2015, 06:10 PM
  3. Fanuc 10T Turret Rotation Problem
    By ehsan72 in forum Fanuc
    Last Post: 06-10-2013, 03:14 PM
  4. Quill Rotation - Problem?
    By Russ Kaiser in forum Benchtop Machines
    Last Post: 03-16-2012, 03:29 PM
  5. G68 Rotation problem on Fanuc 180i
    By btdmfg in forum Fanuc
    Last Post: 12-05-2008, 01:58 AM
