Re: LB15 Chuck Replacement
hy mshepherd just like Douglas said, try to craft those needed parts at your place or somewhere, in the area.
the nut should be easy
about the drawtube, please consider this temporary solution : keep the old one, and simply craft a nut that will connect this existing drawtube with your newer chuck
if you managed it so far with the internal dimension of the M45drawbar, do you have a real reason to change it to M60drawbar ?
there are many situations when smaller chucks are preffered instead of bigger ones ( with which the machine was originally equipped )
if you decide to craft the M60drawbar, than i wish you to find pretty fast some stock pipe with appropiate dimensions, especially at the interior, because the exterior is easier to be machined; i dont know about your area, but arround here i would contact the guys that are machining hydraulic cilinders ( for excavators, for high pressure instalation ); so i am not refering to the hydraulic cilinder that is behind the spindle, but to the normal ( classic ) cilinder
if you decide to buy one, please consider not to go to Okuma directly, but to those that sell chucks ( like Kitagawa ). Okuma dealer wont refuse you, but it will act like an intermediate ( thus will do what you also should do, but charging extra $$$ ).
Indifferent of crafting a drawtube on your own, or buying it, you should check phisically the dimensions that you need; if you dont do this, and you contact Okuma, than Okuma will simply check for standard technical drawings for your machine, and their drawings may not be good. And you will pay for something that does not have appropiate dimensions; in this case, is good to be able to fix it, but also it may be the opposite, like not being able to fix it : money thrown on the window
kindly !
