585,735 active members*
4,971 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Replacement hy02d223b missing rs+, rs- for rs485
    Apr 2011
    33
    My perfectly running hy02d223b with mach3 control went POP a couple weeks ago. The replacement hy02d223b does not have the second terminal bank in it where the rs+ and rs- connections went. My response from the ebay supplier is as follows, please help me decipher it if you understand;
    greatfunctionitem:
    replied as below:
    Hello, your current this please use external speed control,
    Segment speed control performance better,
    And more versatile.
    The parameters are as follows:
    Pn32 = 3
    Pn03 = 7
    Pn04 = 2
    Pn07 = 2
    Pn10 = rated motor frequency
    Pn12 = rated motor frequency
    The external segment speed is as follows:
    The hardware connection is as follows
    D2: D1: D0 Three control lines are valid as follows
    1: 1: 1 speed 7 (PN26) speed
    0: 1: 1 speed 3 (PN22) speed
    0: 0: 0 speed 0 (PN19 specifies the frequency source, the current specified PN02 speed)
    If you do not understand anything, please tell me that we are working hard to solve the problem for you.
    Jerry
    Boise
    Re: Replacement hy02d223b missing rs+, rs- for rs485
    Looks like you bought a Huanyang copy, rather than a real Huanyang.
    Apr 2011
    33
    Gerry, I think you are exactly correct. I didn't know they exist and got in a hurry for a replacement.
    Dang it!
    Thanks so much for the response!
    Jerry
  1. hy02d223b E.ov.A
    By cjgomes in forum Spindles / VFD
    Last Post: 07-05-2017, 01:02 AM
  2. Replies: 3
    Last Post: 02-22-2017, 08:08 AM
  3. RS485 commands for Huanyang VFD (HY02D223B)
    By bouni in forum Spindles / VFD
    Last Post: 05-07-2015, 04:32 PM
  4. HY02D223B VFD
    By Dave Rothermel in forum Phase Converters
    Last Post: 11-21-2014, 02:12 AM
  5. rs-232 and rs485 bus
    By eloid in forum Mach Software (ArtSoft software)
    Last Post: 03-13-2007, 04:39 AM
