585,784 active members*
4,003 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > A circle, a simple circle. How hard can it be?
Results 1 to 12 of 12
    Aug 2017
    5
    I'm new to CNC having built a 2-axis plotter driven by Arduino, CNC-Shield and GRBL 1.1.
    I can draw a square.
    I now want to draw a circle and have failed miserably for days.
    I have googled on and off for about a week now and looked at dozens of examples. Not one of them does a circle. Not on my machine nor in any of about 5 different simulators I've tried. At best a limp arc, at worst straight lines or nothing.
    Come on.
    A circle.
    Could someone post the GCode to do say a circle centered at X=0,Y=0 with radius 5cm?
    Since I now believe it is impossible. Please check your work here:
    GCode Simulator
    or here:
    https://nraynaud.github.io/webgcode/
    Re: A circle, a simple circle. How hard can it be?
    G0 X0 Y5
    G2 X0 Y5 I0 J-5
    Doesn't work in the first simulator you linked, but works in the second one.
    Sep 2006
    6463
    Hi, if you took the time to learn G code all will be revealed, but you gotta be in it to win it.
    Ian.
    Aug 2017
    5
    G0 X0 Y5
    G2 X0 Y5 I0 J-5
    Yeah... doesn't work on my machine (running GRBL).
    The first command works but the circle doesn't and I get:
    error 33 for G2 X0 Y5 I0 J-5
    Aug 2017
    5
    OK, the circle code works in UniversalGCodeSender but not in GrblController 3.6.1
    I thought these programs just send GCodes to the machine so how can they get different results??
    Different controls read g-codes differently.
    I think that GRBl doesn't allow full circles, only partial arcs.
    Aug 2017
    5
    But GRBL is on my Arduino - I'm just switching between different PC software which both send "G2 X0 Y2 I0 J-2"
    I think that Universal G Code Sender breaks the circle up, and sends multiple arcs to GRBL.
    Aug 2017
    5
    I think I see what's happening. If you're in relative mode (G91) you can't draw circles.
    FAIL:
    >>> G91
    >>> F100
    >>> G0 X0 Y2
    >>> G2 X0 Y2 I0 J-2
    ok
    ok
    ok
    error:33
    SUCCESS
    >>> F100
    >>> G0 X0 Y2
    >>> G2 X0 Y2 I0 J-2
    ok
    Is there any way to just draw a circle centered from wherever you are?
    You can, but the code is different.
    G91
    G0 X0 Y2
    G2 X0 Y0 I0 J-2
    Jul 2019
    it's really hard for me
    Hello, in this article it is very well explained (it is in Spanish but you can translate it) https://www.geniolandia.com/13120889...-con-codigos-g
  1. Replies: 0
    Last Post: 09-14-2015, 05:18 PM
  2. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  3. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  4. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
