585,729 active members*
4,488 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 to Consew Type Servo Sewing Machine Motor
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Jan 2014
    9
    Re: G540 to Consew Type Servo Sewing Machine Motor
    Hi Ron, thanks! I'm working with the basic green opto isolated "5 axis breakoutboard" you see everywhere. Upon further inspection I saw that this too needs external power to provide the analog 0-10V for the spindle control. So maybe it indeed boils down to the same situation as with the g540. I feel warned though by John as he stated the connections at the 5V input of the Consew controller could very well be live. Zapped myself once before during reinstallation of a bandsaw motor controller.housing....
  2. #22
    Mar 2007
    2083
    if your BOB is like this
    Attachment 386924
    from the photo it looks like a cut down version of the TX14175 example in post 17
    and will be like this
    a 5V supply from a USB port powers the IC's that connect the printer port to the stepper drivers
    a 12 to 24V power supply is reduced by the on board 10V regulator that powers the LED's in the 5 input opto-isolators that you connect your limit switches & e-stop to and the PWM to analogue converter circuit
    this is inter connection between the limit switches & VFD is a possible danger depending on your speed control board
    for example the FC250 board used in the CL300M mini lathe would make any limit switches live !!
    as the FC250 board has the speed control potentiometer connected to the positive terminal of the mains bridge rectifier
    FC250 speed control
    main board
    Attachment 386928
    daughter board
    Attachment 386930
    john
  3. #23
    Jan 2014
    9
    Hi John,
    Yep that's the one. In the meantime I've joined the taig facebook group because the sewing servo's are a really popular replacement for mini mill and lathe type stock motors. There was quite some discussion about driving a consew type motor from software. Unfortunately I didn't really see people talking about the "live" connections. I did see that some people over there are using a little "voltage to current isolation transmitter circuit" between the breakoutboard and the consew controller that converts 0-10V to 4-20mA which together with a 250 ohm resistor would deliver the 1-5 volt range that the consews like to have. Voltage to Current 0-5V/10V/15V to 4-20mA Isolation Transmitter Signal Converter | eBay
    Does this solution also provide some kind of isolation from the dangerous voltages?
  4. #24
    Mar 2007
    2083
    I can not see any opto-isolator on the 0-10V to 4-20mA board to provide any isolation
    as I have not used or worked on a Consew board , I would need comfirmation the potentiometer connections are isolated from the mains
    may be someone at the taig facebook group could confirm the consew input is isolated
    that's why I looked at the CNC4PC's PWM to analogue boards
    john
  5. #25
    Jan 2014
    9
    Hi John, I can confirm that the consew connections are indeed unisolated! Someone already has fried his G540 because his multimeter probe slipped and touched a part outside the isolated circuit. I'll stick to manual control.
  6. #26
    Mar 2007
    2083
    I expected that would be the case
    Working on line equipment all ways concentrates the mind !
    I'm not sure heath & safety will allow it these days
    but as a 18 year old apprentice I had a job rewiring vibrators that kept powders in a mixing room flowing
    one at a time , each had to be disconnected from a live 240V mains supply and then connected to a new live circuit !!
    John
  7. #27
    Jan 2014
    9
    What?! I'm not sure today's peoples attention span would allow having such a job either (including myself ).
  8. #28
    Mar 2007
    2083
    this video of men working on live power lines makes my working on broadcast television monitors look safe (EHT for the CRT is only 24KV)
    https://youtu.be/GxDKVAYJ_t4
    John
  9. #29
    Jan 2014
    9
    LOL My god, that's a ballsy endeavour. Respect
  10. #30
    Dec 2005
    436
    Ron Thompson: could you post a higher resolution file of the schematic ? The version you posted is very hard to read and the Yahoo group has been cancelled.
  11. #31
    Oct 2005
    99
    I don't have a Taig mill or a Consew motor any longer. But the info is still available on the Facebook group. https://www.facebook.com/groups/Taig...nd.Mill.Group/
  12. #32
    Dec 2005
    436
    Thanks Ron Thompson.
    Can you give a few words on how it worked or didn't, max cutter size, performance, rpm stability etc?
  13. #33
    Oct 2005
    99
    I don't remember much about it. It worked using Mach3 to control the spindle speed and was a very strong motor. I used it mainly to do away with the skinny belts. Ask on that group and they can tell you all about it. I bought a Haas and haven't looked back.
Page 2 of 2 12
  1. Accuracy and positioning servo will depend on the type of motor?
    By Qwerfk in forum Servo Motors / Drives
    Last Post: 01-10-2013, 02:06 AM
  2. Servo Motor Size for Bridgeport type machine
    By native34 in forum Bridgeport / Hardinge Mills
    Last Post: 08-26-2009, 08:25 PM
  3. Brush Type Servo Motor Source?
    By Lemo in forum Servo Motors / Drives
    Last Post: 06-20-2007, 08:01 PM
  4. Sewing machine Servo?
    By Max Power in forum Servo Motors / Drives
    Last Post: 11-16-2006, 03:16 AM
  5. Anyone know where to get this exact type of servo motor?
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-18-2006, 04:58 AM
