585,717 active members*
4,034 visitors online*
    Jun 2014
    6
    Laser tube hisses but does not fire
    I've just changed a power supply on my laser cutter as well as a fuse at the main power to the machine.
    Everything seems to be ok with this setup but now I just hear a hissing from the laser tube when I fire a test pulse but the laser doesn't fire. :/
    Has anyone experienced this or know what the matter may be?
    J.
    Feb 2022
    Re: Laser tube hisses but does not fire
    Hey Jaymez10, I appreciate it's been a while since you posted this but did you ever find out what was going on there? All the things you've posted sound similar to what I'm experiencing at the moment. It's like the tube is arcing at the positive end inside the silicone sealed connection. Thanks
    May 2022
    No one wanted to help you (((
    Feb 2022
    11
    Hi , if you replaced the power supply and it is not working ,making arcs at laser tube section , seems like your laser tube is damaged , need to replace it , only do not continue working/ sending pulses to prevent new laser power supply failure
    best wishes
  1. Laser suddenly won't fire - tube or power supply?
    By jbarber in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 08-16-2020, 03:41 AM
  2. Laser tube won't fire the beam
    By Pierke in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-06-2017, 11:27 PM
  3. G weike laser won't fire. Help trouble shoot power supply, controller or tube.
    By garagefela in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-15-2016, 04:37 AM
  4. Burned on only positive laser tube end when test fire
    By 18111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2013, 07:00 PM
  5. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
