585,971 active members*
4,059 visitors online*
    manual 4th axis milling
    Hey guys.
    I have a custom job to fabricate a couple of this benches. The legs are fluted with continuously changing radius. Perfect job for CNC.
    I am eagerly waiting for CNCRP to start selling 4th axis kit which would make continuous 4th axis machining a bliss but for now this is a question of positioning and indexing the stock.
    I have an old Vertex dividing head and a tail stock. Looks perfect for 4 sided flip milling. Actually, almost as many sided flips as I wish. Divider will go up to a 100 if I remember correctly.
    Ordered 1 pc Lathe Chuck 6" 4Jaw Independent w/Back Plate 1-1/2"-8TPI K72-160 sct-888 with the backing plate.
    Going to be setting up to mill on Sat.
    Any recommendations on small CNC bits to clean the fluting?
    Re: manual 4th axis milling
    Legs are about done. Will start on skirts tomorrow.
  1. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  2. Manual milling?
    By spacetorque in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2015, 11:47 AM
  3. MANUAL MILLING MACHINES
    By JMECKES in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2009, 01:41 PM
  4. Manual milling in Houston
    By davo727 in forum Employment Opportunity
    Last Post: 12-28-2007, 03:35 PM
