585,927 active members*
3,836 visitors online*
Results 1 to 7 of 7
    24221
    LinuxCNC Screen resolution.
    I am looking at checking out LinuxCNC as a viable option, anyone know what the minimum screen resolution is? I have some Kiosk touch screen displays that are 640 x 480.
    Other systems I have tested overscan and make them unusable.
    Al.
    Albert E.
    Jul 2005
    2415
    Re: LinuxCNC Screen resolution.
    The screen resolution is up to the GTK based screen design. None of the default ones are that low of a resolution. You may have to roll your own
    more info here : http://gnipsel.com/linuxcnc/gui/index.html
    Oct 2016
    29
    My first question would be-what inputs do the kiosks take? hopefully vga.
    then what video card is in your computer?
    24221
    I re-checked, they actually go to 800x600, but in trying out Kmotion for example, they overscan.
    Al.
    Albert E.
    May 2015
    686
    This says the minimum screen is 1024 x 768 but I seem to remember running the default axis GUI on a 800 x 600 monitor. It was a long time ago.
    System Requirements
    Rod Webster
    www.vehiclemods.net.au
    Jul 2005
    2415
    You can drag and resize the screen in LCNC but you can't make it smaller than the native resolution the screen was created in. When you build a screen in Glade you tell it the overall size at the beginning. The screen objects come in preset pixel sizes Some of the objects are resizable (larger) some are not. If the monitor won't do the resolution the video card won't make it higher.
    Its hard to fit much stuff on 800 X 600 and if you make the buttons or numbers too small they get really ragged.
    Jul 2003
    1754
    This is a virtual box - 800X600 and axis interface.
  1. What are the screen resolution sizes you are using on your Mach3 computer?
    By selrahc in forum Mach Software (ArtSoft software)
    Last Post: 02-04-2017, 09:44 AM
  2. Fagor 8020 Screen and axis problems. screen waving?
    By dirtrider23 in forum Fagor Automation
    Last Post: 12-17-2016, 03:06 AM
  3. Replies: 2
    Last Post: 09-02-2011, 03:44 AM
  4. Screen resolution problem
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-10-2011, 02:04 AM
  5. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
