585,735 active members*
4,882 visitors online*
    Dec 2016
    4
    Mach4 can't get it to home x or y but Z ok.
    I just installed and setup Mach 4 (upgraded from Mach3) with ESS.
    When trying to home it only homes the z axis then stops. I've tried just homing the x and y separate but nothing happens. Motors don't move and DRO's don't move.
    The Motors and DRO's work fine on all axis when I jog so I know they are hooked up right and talking to the ESS.
    The only difference is the X and Y are run by a motion controller and the Z is just a driver. Not sure if I should be looking there anyway because like I said everything jogs just fine and the Homing buttons not working for just x and y.
    Am I missing something in the setup?
    Re: Mach4 can't get it to home x or y but Z ok.
    Can you elaborate on this, because it makes no sense.
    All motors need drives, and they all need the motion controller to send them step/dir signals.
    Dec 2016
    4
    Well yes, your right the z is a drive but a more simple stepper motor driver where as I have the x and y hooked up to an Allen Bradley Kinetics 300 motion controller.
  1. Mach4?
    By AngelT in forum Machines running Mach Software
    Last Post: 08-30-2019, 04:26 PM
  2. Mach4 & ESS Warp9
    By rchristie in forum Mach 4
    Last Post: 06-30-2015, 11:30 PM
  3. Mach4
    By loddie in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-08-2014, 11:38 PM
  4. Mach4 at CabinFever
    By Trotline in forum Mach Software (ArtSoft software)
    Last Post: 05-26-2013, 03:14 AM
  5. Mach4 and G-Rex
    By Death Adder in forum Mach Software (ArtSoft software)
    Last Post: 04-20-2006, 07:23 AM
